High Pressure Oil line - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-01-2013, 01:49 AM Thread Starter
im new to the forum and to the 7.3 PS. i am looking to buy a 96 f250 4x4 the guy said it runs great but the right high pressure oil line needs the o-rings replaced is that something to worry about?
Helim is offline
post #2 of 9 Old 07-01-2013, 08:31 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Did he say where the oring is? There are several o-rings in the high pressure system. Usually it is in the IPR or ICP that needs the o-rings. The base of the fittings that go into the heads (that the HPO hose connects to) has o-rings, there are two large o-rings in the front and back of each head, and the are two plugs in each head under the valve cover that have o-rings.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 9 Old 07-01-2013, 08:41 AM Thread Starter
he basically said the pressure line that is on mounted on the right side of the engine needs the o-orings replaced the truck has 157k on it and he wants 4500.00 for it so im just not sure if it is a lemon or not it runs good though
Helim is offline
post #4 of 9 Old 07-01-2013, 08:50 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Next time you are there look for oil in the engine valley. If there is no oil on the ground then it can't be the big o-rings, those blow oil like crazy. Oil in the valley can come from several places. Get the truck hot and pull the oil fill cap. Hazing is fine, smoking is bad. Flip the cap upside-down and place is back over the port it came from. Does the engine blow the cap off or does it wiggle around a bit with the motor.
Sounds like quite the find there and for the price. If you like it then I say buy it. Note to you that these engines are expensive to fix. More if you are not handy with tools. 15 Qts of oil and filter can set you back a Bill if you are not savvy. Walmart has good prices on that stuff. Good luck
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #5 of 9 Old 07-01-2013, 08:53 AM Thread Starter
im a ford guy and always done my own work but ive never owned a diesel
Helim is offline
post #6 of 9 Old 07-01-2013, 09:02 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
It's...............different. Remember that these are not Ford engines and they were not meant to go into a truck. Some things are quite the tight fit in there. No timing chains, 2 oil pumps, cramped exhaust path, first (I believe) electronically controlled diesel in a Light Duty truck, and piss poor intake and exhaust. The CPS is a known weak point for the engine. Have a spare and 10mm 1/4 drive deep ratchet/socket in the glove box, ALWAYS. First chance you get pull the IDM and open it. If all good on the inside reseal the box as water is known to get past the old gasket maker seal. Pull the FPR and clean it. You'll more than likely find it all plugged up. A well loved engine will give you many many miles.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 9 Old 07-01-2013, 11:44 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
There are o-rings at the fittings where the hoses go into the HPOP and where the fittings where the hoses go into the heads (the hoses themselves don't have o-rings as therey are flared). Here are the factory part numbers for those:
(Ford) 5C3Z-9N693-A, (International) 1823790C1 (o-ring for HPOP hose to pump joint)
(Ford) F4TZ-9N693-A, (International) 1815874C1 (o-ring for HPOP hose to head joint)
They are regular (I want to say the might be) -5 and -6 o-rings, but whatever the size, make sure you use Viton o-rings. I had one of the HPOP fitting o-rings blow and lost 4 quarts in 10 miles (as usual my wife was driving it at the time). Cheers!
Patrick Feeley is offline
post #8 of 9 Old 07-01-2013, 02:07 PM Thread Starter
Well thank y'all for the inputs so do would you recommend getting the truck
Helim is offline
post #9 of 9 Old 07-01-2013, 02:19 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Manual or Automatic? I think I would if the body is still good with no rot. That's personal thing as I can't stand bodywork or how much body shops charge.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
