best glow plugs for 96 7.3? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-30-2013, 07:33 PM Thread Starter
quicknick106z's Avatar
whats the best?
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
post #2 of 9 Old 06-30-2013, 08:02 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Beru/motorcraft, oem don't swell up and get stuck in the head
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 07-01-2013, 04:10 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
I put Diesel RX GPs from Rosewoods in my dually. They have been good for 2k...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #4 of 9 Old 07-01-2013, 08:07 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Asking for the best is going to start a discussion. I use Ford/Motorcraft for the same reason Kris mentioned. I don't care if they last 3 years or one winter. I want them to come out at the end.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 9 Old 07-01-2013, 08:16 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Motorcraft ZD10 is by far the only GP's that should be runn in these OBS trucks
2000-7.3L is offline
post #6 of 9 Old 07-03-2013, 09:33 AM
Hillbilly Deluxe
Quoted: 2 Post(s)
I disagred completely with this. My black truck has autolites in it with over 100k on them and no issues. They were pulled out about 25k ago when inj were installed and they looked good so they went back in. Jim at Rosewoods is who got my Diesel RX GP's from, he swears by them, and all he does is powerstrokes.
Sent from AutoGuide.com App
Seth
Stroked_NY_023
post #7 of 9 Old 07-03-2013, 10:48 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
Suit yourself, but after being on various PSD forums since about 1998 or so, I've read too many horror stories about Autolite plugs. No way they are going in mine. Motorcraft/Beru only. Cheers!
Patrick Feeley is offline
post #8 of 9 Old 07-03-2013, 05:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I don't like auto lite spark plugs in gassers
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 9 Old 07-04-2013, 07:21 AM
Quoted: 77 Post(s)
Also agree on Beru/motorcraft. I've done to many stuck glow plug removals for people that use other glow plugs and it is a huge P.I.T.A.
I do like Autolite spark plugs
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
