weird a/c problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-30-2013, 04:41 PM Thread Starter
weird a/c problem
after a 2 hour trip today in humid 85* weather I noticed the a/c wasn't blowing out of the vents but the blower was running. got home and took the glove box off to see it the blender door was stuck. as I was standing there, on the passenger side, the truck started pouring out water from the evaporator under the hood. I know it's supposed to drip but this was a steady stream, and alot. as soon as that happened air started coming out of the vents. did it freeze up and block the air from going through?
tony0713 is offline
post #2 of 6 Old 06-30-2013, 06:17 PM
That's what it sounds like to me. Could be low on freon or something is dirty.
2015 F-350 Lariat SRW CC
Sold to my dad:1996 F-350 XLT Crew Cab
2x4 Dually 7.3 with 80,000 miles as of 3-10-15
YJSONLY is offline
post #3 of 6 Old 06-30-2013, 06:54 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Make sure your drip line isn't plugged up. Not enough airflow over evap will freeze it up or an irifice tube that's plugging up
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 6 Old 06-30-2013, 07:16 PM Thread Starter
orphis tube is about a year old. where is the drip line. I looked under the truck but couldn't tell where the water was coming from.
tony0713 is offline
post #5 of 6 Old 07-01-2013, 05:34 PM
dr.deere's Avatar
Quoted: 19 Post(s)
There should be a plastic hose coming off the bottoms of the evap housing somewhere I haven't really looke in these pickups yet for it though
dr.deere is offline
post #6 of 6 Old 09-02-2013, 03:34 PM Thread Starter
I just recharged it after I put a new condenser in.
there was no hose. just a hole.
problem happened again today. took a look under when it started dripping. it's coming out of the seam at the front of the evaporator box, instead of the drain hole in the back near the firewall. I blew air to try and clean the drain but it seemed clear. also noticed the evaporator box doesn't have it's insulation anymore, would that effect it?
can I just drill a new hole up front and call it a day?
tony0713 is offline
