K & N air filter replacement help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-30-2013, 07:58 AM Thread Starter
blackgold9838's Avatar
Good day. I've been reading older posts regarding the K & N air intake filter and now I'm concerned about the quality of the filter. I've read about dusting issues and swapping the filter out. My truck had the K & N filter mod done to it by the previous owner and I thought it was a good thing until I started reading about other users opinions. I think I'm convinced now to swap out the filter for a replaceable element like the napa 6637 or the fram equivalent. I don't have the stock air intake pipe any longer so I'm wondering if these other filters will direct fit on my existing K & N intake pipe or if I have to do some more work. I'd appreciate any feedback.
My truck is a 1996 F350 Crewcab 4x4 7.3L PSD DRW.
Sent from AutoGuide.com App
blackgold9838 is offline
post #2 of 8 Old 06-30-2013, 08:11 AM
I'm not sure the diameter of the k&n intake tube. But the 6637 has 4 inch opening
2002 F-350 7.3 ex-cab short bed Beans 6 Pos
6 inch lift, 35,s, 4 Inch Turbo Back, 6637 intake
Foil delete, 05 harley front end, 08 Tailights
Tinted cab lights, and this and that and this
Z-STROKE is offline
post #3 of 8 Old 06-30-2013, 08:28 AM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
Also, If you have everything stock from the Crankcase Breather Adapter back to the Turbo, you could just get a Tymar setup (Cary at CT Performance sells them) since it has a new hose from the breather adapter to the exhaust elbow that attaches to the filter. Plug-N-Play! Cheers!
Patrick Feeley is offline
post #4 of 8 Old 06-30-2013, 09:00 AM
I originally had the K&N filter and used the entire setup when I did the modification to the 6637.
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #5 of 8 Old 06-30-2013, 06:05 PM Thread Starter
One other question that came to mind. Once the 6637 filter is installed, what do I need to do to keep it dry? I'm nervous that rain or other moisture will get on the paper filter rendering it basically useless. The stock one is encased in a plastic waterproof box and the K & N is covered in oil from the recharge kit. Any thoughts?
post #6 of 8 Old 06-30-2013, 06:32 PM
Quoted: 9 Post(s)
If you get the Donaldson filter, it is water-resistant. Folks from snow country and Washington/Oregon area have not had problems with water. I did not have any issues on my 94's setup (and we get snow here too). Cheers!
post #7 of 8 Old 07-01-2013, 12:02 AM
BIG Laing's Avatar
The oil on the K&N filter gets sucked off by the turbo pretty quick too! then rendering the K&N worthless.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #8 of 8 Old 07-01-2013, 11:50 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Just get a Tymar intake, comes with everything needed to do it correctly. PM me if I can help.
CT Performance, Inc. is offline
