7.3 swap - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-29-2013, 06:13 PM Thread Starter
7.3 swap
I have two 1995 f350s one with a 7.3 and other a 351, the 7.3 has a rotted frame and the 351 is mint, body frame interior ect.. I started pulling the motor out of the 7.3 to swap into the 351. I'm looking for input from someone that's done a swap. I know whats involved as far as wiring and transmissions and radiator support, is the Front cross member the same?
cbates85 is offline
post #2 of 3 Old 07-06-2013, 11:10 AM
bump.....I plan on doing the same!
The front crossmember is different from what i remember
2005 F350 FX4 CC LB LARIAT 6.0L Diesel -SOLD
2012 F350 4X$ CC LB LARIAT 6.7L Scorpion
BLACK and ADOBE
RECON Lights
LEVELED.........My Black Stocky!!!!
Adamvabeach is offline
post #3 of 3 Old 07-06-2013, 11:13 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Motor mounts are different, and the core support that holds the rad is different, the cross member is the same afaik, just need new fuel lines
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
Tags
7.3 , crossmember , f350 , swap
