2wd to 4wd swap? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-29-2013, 10:11 AM Thread Starter
2wd to 4wd swap?
I have a 97 2wd and I'm kind of not liking that its not a 4wd truck. What would it take to do a 4wd swap? I'm asking because I do want to put a lift kit on the truck but I don't see the point in a lifted 2wd and I live in New York in an area when it decides to snow, it dumps a truck load. The truck it'd be going on also has 322.5k miles on. Is it really worth the huge expense?
MossyOakSwamper is offline
post #2 of 10 Old 06-29-2013, 10:29 AM
01Crewcab7.3's Avatar
My advice, sell it and get a 4wd. It can be done but it will take a lot of work and money. You will need a dana 60 which is $1k +/- new tranny, transfer case, drive shafts, wiring harness, PCM, and I'm sure there is more I'm forgetting. IMHO it's not worth it.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 10 Old 06-29-2013, 10:30 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Find a truck that's been rear-ended and buy the whole thing! If you buy everything separate the cost will climb sky high. You should be able to find an obs for pretty cheap. Make sure it's a 97 f350 so you get the stronger front end and more reliable suspension parts.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 10 Old 06-29-2013, 10:32 AM
Quoted: 8 Post(s)
I bet you can find a wrecked truck for under $1500... Shipping it without your own trailer (or borrowing one) is a different story.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 10 Old 06-29-2013, 10:33 AM Thread Starter
Well, I'm throwing this idea out the window now lol. I could think of a lot of better ways to throw around a that kinda money.
post #6 of 10 Old 06-29-2013, 03:14 PM
Quoted: 8 Post(s)
Aawwww, don't be scared! Lol
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 10 Old 06-29-2013, 03:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Don't be afraid of the challenge and a slight expense, couple of us are doing duallies with 05+ axles, keeps it coil sprung, just gotta find tranny, t case, axles, driveshafts, and some shift linkage
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 10 Old 06-29-2013, 04:44 PM Thread Starter
If I had the time and the money to do it, I totally would but it wouldn't be a smart thing to do when I could spend it on more important things
97 F250 Extended cab
2wd
336k miles and going up!
post #9 of 10 Old 06-29-2013, 05:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Priority is key, I'm getting my dually done a little at a time here, have trans and t case, but no axles or linkage lol, but if you decide to go through with it then good luck
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 10 Old 06-30-2013, 04:53 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
I am converting my 95 cclb dually to 4x4 using 08' axles and suspension. For the most part it is all bolt on with some minor fab for track bar. It is EXPENSIVE though, but i will have the truck that i want and not have spent $60k.
On another note !!!!
You are not to far from me, i grew up in Chenango county!! You should also join our NY chapter!!! Here is the link...
Empire State Strokers - Ford Powerstroke Diesel Forum
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
Tags
1997 f250 , 4wd , coversion
