superduty front lift springs in a obs ?s - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-29-2013, 06:17 AM Thread Starter
97dieselstroke's Avatar
So i found a set of 6" lift springs from a superduty for 150 bucks my question is could they fit and would doing a shackle flip in the rear even things out? im guessing about 3" ftom the flip. pros and cons on doing this are appreciated i know its probably gonna be a pretty stiff ride with thoes springs but thats pretty cheap in my eyes. thanks all.
97 f350 cclb 4wd xlt 7.3 e4od 34x12.5 Bfg allterrains 3" diamondeye s/s downpipe to 4" to 5" dual black turnout stacks, aux trans cooler, trans temp guage,diy 6637 intake, ts 6 pos chip. fpr shim, tc lockup switch, 10k mod
95F350 CCLB xlt 7.3 zf5 4wd 4" lift 35" procomp extreme all terrains 3" diamond eyes dp 4" straight ex. diy 6637
97 f250 eclb xlt 7.3 e4od 4wd bone stock
97dieselstroke is offline
post #2 of 5 Old 06-29-2013, 06:55 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You will need a RS kit, at that point you will end up 9" min lift in the front..time for some $$$ mods to do that. Is that really how high you want to go?
PM me if I can help.
CT Performance, Inc. is offline
post #3 of 5 Old 06-29-2013, 07:20 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
it will require a RSK designed for the longer SD springs. PMF and SKY MFG is who u will have to contact for these kits. ^^ cary beat me to it
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 5 Old 06-29-2013, 07:53 AM
Quoted: 3 Post(s)
Not really....I developed this mod in 99...
post #5 of 5 Old 06-30-2013, 04:58 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
The SD springs will not just bolt up you will need an RSK as mentioned above.
I am running SKY 4.5 RSK with SD v-codes and a 2" AAL which gives me 6.5" of lift, enough to clear 37" tires. In the rear i have the SKY RS kit and 2" lift springs to level it out. Ride MUCH better than the OBS springs.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
