trans lines - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-29-2013, 05:44 AM Thread Starter
dirtcrew51m's Avatar
Quoted: 6 Post(s)
trans lines
Replacing the trans lines, rotted and cant be trusted, most likely going to do away with the stock cooler and put an external cooler on, are the fittings on the trans a standard 5\16 flare? Or are they pushlocks?
dirtcrew51m is offline
post #2 of 19 Old 06-29-2013, 06:56 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Do a upgrade to SD lines and add a cooler to the back of the bumper.
We carry the line kit.
Line F81Z-7A031CE
Line F81Z-7A030CA
By Pass Tube 2C3Z-7H322-BA
LPD47391 Tru-Cool
CT Performance, Inc. is offline
post #3 of 19 Old 08-20-2015, 03:54 AM
Line F81Z-7A031CE
Line F81Z-7A030CA
LPD47391 Tru-Cool
I am thinking of doing this here in the next 6-8 weeks as well. Does anyone have any pics of how this fits together? I assume these fit to the stock OBS hard lines and line up with the cooler placement in the bumper and it is sort of a no-brainer once you get it set in place?
ZUBE2000 is offline
post #4 of 19 Old 08-20-2015, 05:06 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
zube - talk to matt (bigfuel) He has drawings and i think pictures
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 19 Old 08-20-2015, 06:16 AM
Will do. Thanks!!
ZUBE2000 is offline
post #6 of 19 Old 08-20-2015, 06:44 AM
Phillipjon's Avatar
Quoted: 77 Post(s)
Line F81Z-7A031CE
Line F81Z-7A030CA
LPD47391 Tru-Cool
This is what I have, and it works great!
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #7 of 19 Old 08-20-2015, 07:29 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
I don't have any good pics on me at the moment but I also used Cary's "kit". Our trans has standard 3/8" flared fittings slimmed down to our 5/16" lines. Installing Cary's setup is a direct swap in except that the feed line points in the wrong direction for our radiator setups. Easy fix, I bent them back to (mostly straight) and used 3/8" rubber to my radiator. The oil cooler lines in the radiator are 1/4" NPT to 3/8" HB (factory is 1/4" NPT to 5/16" HB). Tru-Cool mounts right behind the middle of the bumper and tech screws right in place. Remind me tomorrow to get a pic of the setup. You MUST use the bypass when going to the SD setup.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 19 Old 08-20-2015, 07:56 AM
Phillipjon's Avatar
Quoted: 77 Post(s)
I did not use the bypass tube, while still using the superduty 3/8 tranny lines.
https://www.strictlydiesel.com/p-272...elete-kit.aspx
post #9 of 19 Old 08-20-2015, 07:59 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Sorry, I meant that as you can't use the SD lines without something in there to take up the gap.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #10 of 19 Old 08-20-2015, 08:03 AM
Great info fellas! Thanks!
PS: Phillip, nice truck! Are those SD V-codes with that RSK?
ZUBE2000 is offline
The Following User Says Thank You to ZUBE2000 For This Useful Post:
Phillipjon (08-20-2015)
