new parts still no start needs to move now - Ford Powerstroke Diesel Forum
post #1 of 25 Old 06-28-2013, 12:03 PM Thread Starter
Exclamation new parts still no start needs to move now
Replaced one of the fuel lines that goes to the regulator then started up and ran like crap replaced cps started up and still ran like crap no acceleration almost seemed like a miss....got it home sat for a day tried a different cps and no start chugged and wanted to start but wouldn't had white smoke changed to different cps same thing......found burnt pins on the uvch changed all that now turns over and I get no smoke no start tach moves a bit wts light comes on and off as normal I'm at a complete loss I have no clue what I got going on.
I'm needing to be moved out of my current place before Monday which means truck needs to run by Sunday help is greatly appreciated.
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #2 of 25 Old 06-28-2013, 03:21 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Not being a smart *** but did you fill the fuel bowl? Check the fuel filter, FPR screen, make sure you are getting fuel?? Check IPR?? No oil pressure in the heads means no start.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #3 of 25 Old 06-28-2013, 03:21 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Fuse 22 good? Voltage to the center pin on the UVCH pig tail with key in run?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 25 Old 06-28-2013, 03:42 PM Thread Starter
Not gonna lie I've been leaning towards oil related I'll check fuel bowl stuff and fuse 22 along with center pin and IPR
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #5 of 25 Old 06-28-2013, 09:56 PM Thread Starter
Well no fuses are blown
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #6 of 25 Old 06-28-2013, 09:58 PM
01Crewcab7.3's Avatar
Is your hpop reservoir staying full?
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #7 of 25 Old 06-29-2013, 05:37 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I would hook a scanner up to it and check for random injector codes that don't make sense. That sounds similar to when my idm was bad in my 97 after I put new motor in(bought non running truck)
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #8 of 25 Old 06-29-2013, 06:08 AM Thread Starter
I dont have a scanner or even access to one
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #9 of 25 Old 06-29-2013, 07:30 AM
dr.deere's Avatar
Quoted: 19 Post(s)
That's too bad that would help greatly
dr.deere is offline
post #10 of 25 Old 06-29-2013, 07:55 AM Thread Starter
Ok got it started still runs like crap throwin an ICP code 1280
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
