PS fluid - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-27-2013, 06:09 PM Thread Starter
PS fluid
I have a 1997 350, from the search it looks like I can use mercon V for the power steering pump, but it only specified year 2000 and up..
will my 1997 be good with mercon V?
fstfrd01 is offline
post #2 of 10 Old 06-27-2013, 07:11 PM
Yes. I believe Mercon V is a synthetic blend or use a full synthetic ATF.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
post #3 of 10 Old 06-28-2013, 08:59 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
it will work just fine. thats whats in mine.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 10 Old 06-28-2013, 10:08 AM
Question
Is there someting wrong using power steering fluid instead ATF?
CELAYORK is offline
post #5 of 10 Old 06-28-2013, 10:19 AM
ZMANN's Avatar
Quoted: 1463 Post(s)
It's not a syn blend
Motorcraft® MERCON® V Automatic Transmission Fluid (ATF) and Power Steering Fluid
Premium-quality dual-use fluid for Ford, Lincoln and Mercury vehicles
Can be used in vehicles requiring MERCON® V or MERCON® type automatic
if u want I easy to buy full syn Mobil has a Mercon / V ATF in most parts stores
it's what I run
We Miss you Ronnie
ZMANN is online now
post #6 of 10 Old 06-28-2013, 10:28 AM
Smile
it's what I run
Ah, OK, thank you, Im going to change it as soon as I can.
CELAYORK is offline
post #7 of 10 Old 06-28-2013, 03:07 PM
ol_Blue97's Avatar
the spec on what ford calls for is atf, not standard powersteering fluid. ^^^ so u may wana flush it and change it but u prolly will not have a problem with what your running now
FRANK THE TANK
post #8 of 10 Old 06-28-2013, 05:06 PM
Question
Thank you, but the problem is that when my high pressure hose blown, somebody recomended to use standard powersteering fluid, so I did Besides no to be synthetic are there any other issues using it? Should I change it ASAP?
CELAYORK is offline
post #9 of 10 Old 06-28-2013, 05:38 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Someone reported less steering and brake power with PS fluid than with ATF.
I would flush it when you get a chance with regular ATF or full synthetic ATF.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 10 Old 06-28-2013, 05:49 PM
it's what I run
Chemical Name
PETROLEUM DISTILLATES
HYDROTREATED HEAVY
PARAFFINIC
PETROLEUM DISTILLATES,
HYDROTREATED LIGHT
PARAFFINIC
CATALYTIC, REFORMER
FRACTIONATOR RES.
PARAFFIN OILS - LUBRICATING
OILS (PETROLEUM) C15-30
HYDROTREATED, NEUTRAL OIL
BASED
This is from the MSDS. A full synthetic will not have petroleum in it.
Chris
