DIY transmission service: do's and don'ts ? - Ford Powerstroke Diesel Forum
post #1 of 31 Old 06-26-2013, 10:49 AM Thread Starter
579
579's Avatar
I just did a vehicle history repot on my 97 f350 cc 4x4.
It was a free one I found online. It's never had a tranny service and my truck currently has 238k miles on it. I've only had the truck a month and so far so good but it's my daily driver and I want to ensure it stays that way.
I want to change the filter but I'm reluctant to do a flush . I found this while searching
Changing ATF: 7.3L PowerStroke Engine and 4R100 Automatic Transmission. - Diesel Forum - TheDieselStop.com
I just wonder : should just drop the pan, change filter, and replace fluid?
Or should I do the whole flushing procedure ?
I am aware of the hear say involving new tranny fluid washing old clutches out and causing failure. In y'all's experiences how true is this ?
Also do,I need to drill and tap a fitting in the pan for a temp gauge ? I will add one later but not right away.
Thanks
579 is offline
post #2 of 31 Old 06-26-2013, 11:04 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
That flushing article was written by Mark Kovalski, a former Ford auto trans engineer (and a regular, and very valuable, poster on various PSD forums in auto trans related posts). I don't think I would have any hesitation with doing that, but that just my opinion. Cheers!
Patrick Feeley is offline
post #3 of 31 Old 06-26-2013, 02:53 PM Thread Starter
579
579's Avatar
I would trust it as well. Without a doubt.
Thank you for responding .
but I'm worried about bringing all that new detergent in contact with all my 16 year old internal transmission components .... Just planning ahead . I don't want transmission woes again . Just had that. It sucks so bad .
579 is offline
post #4 of 31 Old 06-26-2013, 02:58 PM
copenhagen's Avatar
"Also do,I need to drill and tap a fitting in the pan for a temp gauge ? I will add one later but not right away."
no tapping required there is a plug on the driver side, right above the pan.
copenhagen is offline
post #5 of 31 Old 06-26-2013, 05:15 PM Thread Starter
579
579's Avatar
Awesome . Thanks ! That's good to know!
579 is offline
post #6 of 31 Old 06-26-2013, 06:17 PM
toad's Avatar
Quoted: 25 Post(s)
The issue with flushing is when the lube shops do a chemical flush. That can loosen stuff up and cause damage. That reminds me I got 35k on my trans and have not serviced it.
1996 F250 crew cab. Hypermax intercooler, Gearhead tunes, 4" exhaust, 6637 intake, Autometer gauges, Dana 60, 6.0 cooling fan, Built e40d, Firestone airbags, Full Force stage ones more to come. SOLD
2003 7.3 F250 Lariat. Mostly stock.
toad is offline
post #7 of 31 Old 06-27-2013, 02:57 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 4 Post(s)
Feedback Score: 3 reviews
How sure are you of the miles on the trans?? Those reports aren't necessarily 100% accurate.
If its does not have an issue now, personally i wouldn't flush. This is what i would do...
Buy this pan(holds more fluid and has a drain plug... http://www.summitracing.com/search/i...material/steel
Then drop the pan and let trans drain, remove TC inspection cover and drain converter. Purchase a GOOD dex3 AFT (synthetic preferably), a new filter, and an after market cooler.
Like this one... http://www.amazon.com/Tru-Cool-LPD47391-Pressure-Transmission-Cooler/dp/B0060NKA1U
I would then completely bypass the rad cooler all together, and remove the secondary cooler if installed, and install the unit above.
Install new filter and pan,fill converter with fluid, install fluid, drive...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #8 of 31 Old 06-27-2013, 04:18 AM Thread Starter
579
579's Avatar
"Install new filter and pan,fill converter with fluid, install fluid, drive..."
That's what I was thinking .... But if I'm already going to drain the tc then I might as well follow through with the flush.
I'm pretty sure the fluid has not been changed in a long long time....
The radiator cooler has been eliminated already and it has a aux cooler on it now. L
It looks stock. It's 11"x10" in size . Do I still need bigger?
Does that one from summit need an extension adaptor for the filter since it holds more fluid?
The description says its a stock pan
Thanks for the links and feedback
My transmission and myself thank you.
579 is offline
post #9 of 31 Old 06-27-2013, 04:23 AM Thread Starter
579
579's Avatar
This one looks pretty radical
http://www.amazon.com/Derale-14208-Transmission-Cooling-and5R110W/dp/B004XONSX0/ref=sr_1_4?s=automotive&ie=UTF8&qid=1372335728&sr=1-4&keywords=Transmission+pan
579 is offline
post #10 of 31 Old 06-27-2013, 04:03 PM
Hillbilly Deluxe
Quoted: 4 Post(s)
The only reason I would say no flush is because its never been done to your knowledge. It may end up loosening up a bunch of crud that could get stuck in the vb or shift solenoid and do more harm than good.
The sell a deep filter, that is the one you want.
As far as the cooler goes I see it this way. Heat is what kills a transmission, so the cooler the better, the more miles you will get out of it. I run a 36 row 6.0 cooler on mine bc I tow a lot with it. My mini is a 5ton machine, I rarely see anything near 130 when pulling it.
Sent from AutoGuide.com App
Seth
Stroked_NY_023
