coolant filter - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-26-2013, 10:41 AM Thread Starter
PowerstrokinIt F250's Avatar
coolant filter
ive seen coolant system kits for sale. I was wandering if anyone has installed this on their truck and if so, is it an easy process and is it really worth doing??
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #2 of 14 Old 06-26-2013, 11:59 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
I had a DIY coolant filter setup on my 94. You can get quite a bit of trash out of the system with one. They can also be conveinient for keeping the SCA levels up since you can get filters with various levels of SCA charge (including none, which is what I used since I had the additive on hand already). Cheers!
Patrick Feeley is offline
post #3 of 14 Old 06-26-2013, 02:11 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Diesel Brad has one too. Brad if you see this can you link us to your install?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 14 Old 06-26-2013, 08:46 PM
Quoted: 8 Post(s)
Here's what mine looked like: TheDieselStop.Com Photo Hosting - NAPA Coolant Filter
It was based on a setup done by a guy called Carpentractor, but the website went aways quite a number of years ago. Cheers!
post #5 of 14 Old 06-26-2013, 08:51 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Awesome Patrick. Thinking of doing this too but closer to the firewall.
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 14 Old 06-26-2013, 09:32 PM Thread Starter
now where did you get the parts for that stuff? im not sure id want mine positioned right there but the diy way cant be too bad
post #7 of 14 Old 06-27-2013, 06:18 AM
ryandamo's Avatar
On mine i bought a dilter basnand some filters, got the fittings from home depot andd made a bracket that attaches to tw 2 empty bolt holes on the alternator bracket, i ties into the heater core send and return since i have the old style rad with no degas bottle
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #8 of 14 Old 06-27-2013, 06:46 AM
Quoted: 8 Post(s)
The filter base was from NAPA, and then it was just a matter of finding the various fittings and making the braket. I would have to go search for the fittings I used (I probably added the filter around 2002 or 2003) or the original parts list from Carpentractor (I made a few changes to "clean" things up a little). The location is actually not bad (if you don't run an IC) since the hoses run fairly similarly to the stock setup. Cheers!
post #9 of 14 Old 06-27-2013, 09:38 AM Thread Starter
well that's why I didn't like the location In case I decided to put an ic on. I thought I remembered seeing one located underneath someones truck close to the rad maybe. I could be wrong though, guess ill just have to get some parts and do some custom fabricating
post #10 of 14 Old 06-27-2013, 09:43 AM
Colin7.3's Avatar
I have a super duty. But I recently installed dieselsites kit. I've only had it on for about 50 mile Now. But I can already tell the coolant in the degas bottle is cleaner. I plan to swap to red ELC this summer and will open the filter up when I do this to see all the junk it collected.
I'm from the heavy duty world and they all have filters. Also the medium duty internationals with the 444e have factory coolant filters. I feel it should have one for that reason.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
