3.73 dually diff? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-26-2013, 09:08 AM Thread Starter
cbarm's Avatar
3.73 dually diff?
Im curious if Ford produced a 10.25 diff for a factory dually pickup with 3.73 gears? I had o e in a custom 4x4 conversion but I didnt know if it was pieced together or not.
cbarm is offline
post #2 of 12 Old 06-26-2013, 09:55 AM
01Crewcab7.3's Avatar
To my knowledge the only gear sets for a 10.25 from the factory were 3.55 and 4.10.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 12 Old 06-26-2013, 02:21 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Nope. Not from the factory in obs trucks.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 12 Old 06-27-2013, 08:57 AM
ryandamo's Avatar
Thry didnt come drom factory but you you can get them aftermarket
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #5 of 12 Old 07-02-2013, 07:48 AM
I am in the process of putting a SD Dana 80 3.73 dually rear in my 4.10 geared OBS Dually. When I finish the project I'll post a how-to. It'll be nice to have the beefier rear, disk brakes, and taller gears.
SuperHatch is offline
post #6 of 12 Old 07-02-2013, 09:17 AM
ol_Blue97's Avatar
What are u gonna do about the different bolt pattern?
FRANK THE TANK
post #7 of 12 Old 07-02-2013, 10:02 AM
I am machining the hub to accept thread-in studs between the existing studs in the correct bolt pattern and turning the hub down to the correct size. I will post pics once I get started on the machine work.
post #8 of 12 Old 07-02-2013, 10:09 AM
ol_Blue97's Avatar
Gotcha... sounds good.
FRANK THE TANK
post #9 of 12 Old 07-02-2013, 10:59 AM
Will be a bit, this project is on the back burner right now. Working on a front end overhaul this weekend... tie rods, bushings, ball joints, shocks, brakes, etc...
post #10 of 12 Old 07-02-2013, 03:03 PM
ol_Blue97's Avatar
even more fun
FRANK THE TANK
