94.5 PSD dead cylinder - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-25-2013, 10:18 PM Thread Starter
cbarm's Avatar
Hey guys, 1st post here, looks like a great site!! I have a 94.5 PSD with 220K miles that has no compression in one hole so Im thinking that it might either be a burnt valve or a hole in the piston. I have it at a shop now and they are gonna pull the glowplug out and stick their lil camera in there to see what it might be. Either way what am I looking at on cost for this? I have found a couple complete trucks with around 180K miles with good drive trains for around $1000. Would it be worth swapping the engine out for one that runs properly, or doing the work myself. This truck also needs a turbo as it is leaking oil out where the downpipe joins the turbo.
Im sure this has been beaten to death here, but I also considered doin an old 12 valve cummins swap. I found one with 140K miles for $1800. How hard would this be?
Thanks in advance for any informative advice!
Chris
cbarm is offline
post #2 of 5 Old 06-25-2013, 11:05 PM
01Crewcab7.3's Avatar
The 12v swap is a good swap but you will be out a lot of money to go that route. I suggest stuffing a used take out in there or rebuilding your engine. I think the benefit to cost ratio is not high enough in my opinion.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 5 Old 06-26-2013, 07:00 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I thought about doing a 12 valve swap in my 97 but factoring in the cost of rebuilding both engines because I wouldn't just put a used one in if I did and then all the other parts plus buying a 12 valve it was more cost effective to overhaul my stroke. I've owned dodge cummins pickups before the 24 valve I had pulled just as good at same mileage only thin is missing a little bottom end grunt with the powerstroke but stick engine for stock engine they run down the highway just as good in my opinion.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 5 Old 06-26-2013, 09:03 AM Thread Starter
cbarm's Avatar
Ok...I did a lil research last night and I didnt realize it was gonna be as costly as it is. What would an approx cost be to replace a piston or burnt valve and is it something I could do myself being reasonable mechanically inclined and a normal set of tools? Or would it just be better to swap it out? I found a '95 7.3 w/ allison tranny out of a schoolbus. Full maintenance re ords and guy says it runs flawlessly but bus was rear ended and cant be fixed. $1500 n I pull em out. Is this a good price? 225k miles.
cbarm is offline
post #5 of 5 Old 06-26-2013, 09:45 AM
Quoted: 48 Post(s)
What, if anything yet, did the laproscopy reveal?
madpogue is offline
