EBV related problem?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-25-2013, 08:13 AM Thread Starter
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
recently been having an issue where after i start the truck i hear a grinding type noise that sounds like something opening and closing witch then makes the old hangers on the exhaust rattle because it never did it before, was told it was the ebv , even when at normal temps when i stop it starts doing it non stop , the flap thing on the end of the turbo was wired open but the wire broke but im sure it still stays open, any ideas?
the 2 wire connectors running behind the turbo has been unplugged
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #2 of 4 Old 06-25-2013, 08:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mite want to re wire it back open, if it's not connected then it can still flap a bit
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 06-25-2013, 08:52 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
what he said
ITS STOCK
SCUFFY828 is offline
post #4 of 4 Old 06-25-2013, 01:09 PM Thread Starter
Quoted: 13 Post(s)
does the rod that's coming out of the turbo on the bottom connect to the part thats under where the flap is??
cause it was disconnected and cant remember what part to wire to
-Jeremy
Got A Few Rides...
