94 7.3 IDI Turbo - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-25-2013, 05:58 AM Thread Starter
94 7.3 IDI Turbo
I am going to look at a 94 f-350 with a 7.3 IDI turbo. It has 314,000 miles with a automatic trans. What are some common problem areas of big expense to look at. I am new to diesels but understand mechanics pretty good so i understand to feel for trans slip and stuff like that just want to know if there are engine issues i can look for. Thanks in advance for any help
busdriver77 is offline
post #2 of 7 Old 06-25-2013, 06:51 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
IDI's are tanks! They are not fast, they are not as readily powerful, they are not quite but man-o-man once it's started you ARE getting from point A to B. This '94 you are looking at may or may not have a turbo. Banks and ATS make whole kits to up the power in these things. I have not owned one but I have two friends with IDIs and they love them.
Don't forget to look here to talk to other IDI owners. IDI Owners
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 7 Old 06-25-2013, 04:13 PM
Quoted: 83 Post(s)
Feedback Score: 4 reviews
The same as other diesel's the two big area's to watch for are excessive crankcase blow by and cylinder wall cavitation. I've owned several and built even more of the 6.9 and 7.3 IdI engines and believe me they can be made to be powerful and fast. The Idi engines are more prone to cylinder wall cavitation because their compression ratio is at least 3 points higher than a 7.3 powerstroke.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 7 Old 06-25-2013, 05:58 PM
c69ss396's Avatar
94 idi's came with a factory turbo...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 7 Old 06-25-2013, 07:24 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Only (roughly) 1/3 did... and 1/3 were powerstrokes.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #6 of 7 Old 06-25-2013, 07:48 PM
Quoted: 83 Post(s)
Turbo was a option in 93/94. The 94 Idi 7.3's with factory turbo where severely detuned so as not to compete so much with the powerstroke coming out in 94.5
Jack
322000 miles
post #7 of 7 Old 06-26-2013, 07:48 AM
ryandamo's Avatar
Another good thing about those is even if the motors grenade, you can get another one cheap and all of the parts are cheap and easy to repair, wish I kept my old 6.9
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
