Manual Swap - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-24-2013, 08:30 PM Thread Starter
PowerstrokinIt F250's Avatar
Manual Swap
looking to do a manual swap on my 95 f350. Im very familiar with the manual transmission setup as i just did a solid mass flywheel swap on my 96. Never had an automatic before and wasn't sure if it would be the exact same length as the manual tranny or if id need different driveshafts?? Also will i need a different PCM?? im just buying all the parts piece by piece but want to make sure i have it all before i start tearing into it. thanks for any help
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #2 of 13 Old 06-24-2013, 09:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You need the PCM and a longer driveshaft, and not sure bout the t case linkage tho, but if you have a chip that can also just be burned into it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 06-24-2013, 09:39 PM Thread Starter
good point. i didn't even think about the transfer case linkage but by the way its setup i would think it would work. i do not have a chip and would rather just get a new pcm if that's not too much of a pain to do.
post #4 of 13 Old 06-24-2013, 10:02 PM
Quoted: 43 Post(s)
Longer rear driveshaft, shorter front driveshaft, shorter t-case linkage (or make your own, as some have). Best thing to have is a scrapped donor truck with the same cab/bed combo, so you can pick everything you need off of it. But it can be done piecemeal.
madpogue is offline
post #5 of 13 Old 06-24-2013, 10:07 PM Thread Starter
well ill keep my out for a donor truck, but you never see any in the junkyards theyre full of rusted out gassers. but no hurry on the manual swap, theres nothing wrong with the auto, im just not an auto kinda guy. i always said id never buy one but couldn't pass this truck up and its the only thing i don't like about it
post #6 of 13 Old 06-25-2013, 03:51 PM
speedracer7c's Avatar
I just finished this swap. Very straight forward but time consuming by yourself in your driveway on your back. You also need the 5 speed crossmember and to make things easier the trans tunnel cover out of the manual.
97 F350 Reg cab XLT 7.3, ZF5 Swap, Diamond eye 4" turbo back,Riffraff 6637, Deleted pedestal and outlet, riffraff billet wheel, Baby Swamps, Ts 6 pos with swamps tunes Glow shift triple gauge pod
340k miles and kicking!
2016 F-250 Supercab 6.7
speedracer7c is offline
post #7 of 13 Old 06-25-2013, 05:53 PM Thread Starter
never thought about the crossmember either. but by the trans cover I assume you mean the floor pan? I already have one I picked up at a junkyard, I also have a brand new pedal assembly, clutch master cylinder, the master cylinder line, slave cylinder, a new clutch fork, and a single mass flywheel clutch kit. all I need is a tranny, the right driveshafts, a pcm, and the manual crossmember. that's all I can think of. when you did the swap did you get a manual pcm or did u get a chip programmed for it?
post #8 of 13 Old 06-27-2013, 09:23 AM
I did neither, I left my auto pcm in. Runs fine throttle is a little touchy but you get used to it. Some guys have complained of a surging idle at start up but mine started perfect the first time and has never surged.
post #9 of 13 Old 06-27-2013, 09:33 AM Thread Starter
wow ive never heard of anyone leaving their auto pcm in. I would think it wouldn't run right like that but maybe im wrong
post #10 of 13 Old 06-28-2013, 03:03 PM
there's a lot of people who have done it. It runs and runs fine. I have no intention of swapping it out unless someone gives me one for free.
Before I took on the swap I read as much info as i possibly could. There is information everywhere.
