Bleed brakes on 97 7.3 PSD help please - Ford Powerstroke Diesel Forum
Old 03-30-2008, 11:39 AM
Send a message via AIM to kx592
Question Bleed brakes on 97 7.3 PSD help please
Im planning on getting new brake lines caseu mine are all rusted up. My only concern is how do you bleed the brake lines on this truck. I cant find any bleeder valves exposed anywhere
Old 03-30-2008, 11:47 AM
Desert Shield/Storm Vet
Should be on your brake calipers
Old 03-30-2008, 01:20 PM
OK thanks man, i knew it had to be on there but wasnt gonna go searching for awhile with out the info, thanks!
Old 03-30-2008, 01:28 PM
Here is a pic of my caliper I had to change out this weekend. The green plastic plug is where the brake line feeds into the caliper and where Im pointing is the bleeder with the rubber cap
Old 03-30-2008, 01:35 PM
Yea I found it, I originally was looking on the bottom or middle of the caliper because it would be the easiest access point but I see its on top, thanks for going out of your way to post a pic. i appreciate it!
Old 03-30-2008, 01:39 PM
You bet
