Rear end - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-24-2013, 01:35 PM Thread Starter
Rear end
Hi so I have a 95 E350 cutaway, It recently just chewed up a break drum adjuster and in the process of doing that the pads, and some of the other internals...I also need a new U joint on the rear end, one of my strut mounts on the axle is looking a little warn and I in general hate the drum breaks, and really am not a big fan of the open rear end. So I was wondering what it might be a good option for a realitivly strait forward swap/where to start looking for something like that.
I want a rear end with out an open diff, and disk brakes.
thanks
Lucas
ledzepp2994 is offline
post #2 of 4 Old 06-24-2013, 02:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Swap in a super duty cab and chassis rear end, Dana 80 iirc, disk brakes, or an f-superduty same set up but really low gears
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 06-25-2013, 04:34 AM Thread Starter
Will that work? It was my understanding that the Truck frame was narrower than the van...
post #4 of 4 Old 06-25-2013, 06:11 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
What's your spring perch width, and is yours currently a dually? Kause a cab and chassis perch width is like 42" iirc, not sure how much narrower you could be
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
