Priming Fuel System? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-24-2013, 07:09 AM Thread Starter
OneBadV8's Avatar
I'm pretty new to these and have to change out the lock ring on my gas tank. I'm assuming I'll have to somehow get the air out of the lines after putting it all back together.
Any good ways to do so or is it just crank for a while, let it sit even longer, and repeat?
OneBadV8 is offline
post #2 of 5 Old 06-24-2013, 07:25 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
If the fuel bowl is empty save some time and cranking and pour fuel straight into it. Once it's running let it idle for a minute. All the air will not run through for 40-60 miles.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 5 Old 06-24-2013, 07:28 AM Thread Starter
OneBadV8's Avatar
So it'll just run rough for those 40 - 60 miles?
OneBadV8 is offline
post #4 of 5 Old 06-24-2013, 07:30 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Yes, little misses and what nots but it works through. Most of the air will miss the injectors and return to the fuel bowl to be bled back to the tank, a tiny bit will remain in the injector area. The stock mechanical pump is very poor at priming the system.
Matt
'97
-Stage II trans.
BigFuel is offline
post #5 of 5 Old 06-24-2013, 07:34 AM Thread Starter
OneBadV8's Avatar
Thanks for the info
OneBadV8 is offline
