Do you need to pull turbo to remove fuel bowl - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-23-2013, 01:46 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
My 95 OBS fuel bowl leaks and im gonna pull it and rebuild it, after watching some videos it looks like everyone pulls the turbo. Is that necessary or does it just make it easier?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 16 Old 06-23-2013, 02:29 PM
c69ss396's Avatar
no need to pull the turbo, It is no where close to being in the way...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 16 Old 06-23-2013, 02:34 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Well the fuel pump is connected to the bowl right? and the lines run under the turbo so you need the turbo out to get to those lines right? or can i take the fuel pump off the bowl then pull the fuel bowl out
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 16 Old 06-23-2013, 02:44 PM
Quoted: 2 Post(s)
The fuel bowl is just connected by a couple rubber hoses that can be easily removed and the pump will come out without pulling turbo too .the banjo bolt is a little tricky to get to though
97 f250 4x4 ccsb
auto
typical exhaust /6637 intake/ chip
add a leaf leveling front
otherwise mostly stock
joshh77 is offline
post #5 of 16 Old 06-23-2013, 02:57 PM
c69ss396's Avatar
The only hic-up is if you have a cali truck, then you have to pull the turbo to change the fuel pump due to the accumulator on it. The fuel bowl can be removed on all obs's with out any issues...
c69ss396 is offline
post #6 of 16 Old 06-23-2013, 03:07 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sweet i really wasnt wanting to pull the turbo just to rebuild the fuel bowl
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 16 Old 06-23-2013, 03:50 PM
c69ss396's Avatar
Replace the hoses while your in there, I was going to reseal mine but when I found a brand new one for $330 that included bowl, filter, regulator, sensor and a new wiring harness. I decided to go that route instead. I ended up selling the old bowl on ebay for $145...
c69ss396 is offline
post #8 of 16 Old 06-23-2013, 06:33 PM
^second replacing the hoses. Got all of them at the local dealer for $25ish and took a few minutes and cuss words to put them in while I had the bowl out.
-Austin
1996 F-250 XLT ECLB 4x4 w/E4OD 119k and counting
6637 intake
Diamond Eye 4" turbo-back exhaust
rebuilt tranny
1998 Buick Regal GS 149k
parts runner with blown head gasket
acprimus631C is offline
post #9 of 16 Old 06-24-2013, 06:17 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Sounds good thanks guys
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 16 Old 06-24-2013, 04:03 PM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
either dealer or an auto parts store ^^ for hoses but as said the turbo is no where near the bowl
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
