doing dana 60 swap and swapping rear axle - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-22-2013, 08:30 PM Thread Starter
ereed969's Avatar
so I'm wanting to do the Dana 60 swap I have a front axle that I can buy for $800 that is 3:55 gears. My truck is currently 4:10 if I find an axle for the back off a f-250 or a f-350that is 3:55 gears is it just a un bolt the old one and slide in the new rear axle. I do want the 3:55. All I do is drive on the highway.. any help is much appreciated
ereed969 is offline
post #2 of 8 Old 06-22-2013, 09:15 PM
95redrifle's Avatar
Quoted: 3 Post(s)
Yes it will bolt right in.
Sent from AutoGuide.com App
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #3 of 8 Old 06-22-2013, 09:20 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Randy's ring and pinion has gears that would be wAy cheaper than a whole axle if your interested in just rehearing the rear. I'm rehearing my d60 for my f250 now got gears for 220
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #4 of 8 Old 06-22-2013, 09:54 PM Thread Starter
ereed969's Avatar
Do you happen to know how much regearing would roughly be
ereed969 is offline
post #5 of 8 Old 06-23-2013, 04:08 AM
the baconator
terryknight's Avatar
Quoted: 144 Post(s)
you should be able to find a rear end for less than a set of gears. i sold mine for $175, it was 3.55s and needed a diff cover, i put a hole it in unloading it. rearing normally costs around $600 an axle here, maybe more or less depending on your labor rates
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 8 Old 06-23-2013, 04:31 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I was basing my statement off the fact ill do the labor myself and never priced rears out I know my bro and I have a couple laying around because they are 3.55
dr.deere is offline
post #7 of 8 Old 06-23-2013, 10:28 PM
m j
the install kit is more then the gears, and I think gears have doubled in price recently to $400
regearing is a better way to go IMO as these rearends have a pinion bearing crush sleeve that goes bad and should be replaced with a crush sleeve eliminator
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #8 of 8 Old 06-24-2013, 01:58 PM
dr.deere's Avatar
Quoted: 19 Post(s)
I just ordered USA standard gears for my d60 steer axle 221 went with the better Yukon overhaul kit for 272 but could get a kit for 170. My gears showed up on ups 3
Business days later. Randy's told me that the USA gears maybe noisy compared to Yukon gears but in a front axle that's not turning them all time and in a diesel it won't bother me
dr.deere is offline
