Help with AE and trans codes on my obs - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-22-2013, 05:18 PM Thread Starter
I have a 96 250 with an E4OD, I get the od light flashing periodically, and rough shifting and slipping. I have AE with the Ford enhanced powertrain, when I hook it up no codes show. It is my understanding that the flashing od light stores a code. Do I need to have it hooked up when the light is flashing? Does AE read the trans codes? Any help/advise would be greatly appreciated, Thanks.
mzwizanski is offline
post #2 of 9 Old 06-23-2013, 03:15 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
yes, when the OD light flashes it sets and stores a code. you can pull it at anytime. I am not familiar with AE so i cant tell you how to do it, but i assume you can.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 9 Old 06-23-2013, 07:24 AM Thread Starter
I thought that was the case, I guess I need to learn AE a little better. Or what other code readers are out there that would pull trans codes and not break the bank.
post #4 of 9 Old 06-23-2013, 08:44 AM
the baconator
Quoted: 149 Post(s)
look for a used snap on brick. should be a couple hundred. just make sure you get the ford enhabced cartridge. that's what i used to use
post #5 of 9 Old 06-23-2013, 10:01 AM Thread Starter
Snap on Brick? is that the MT2500?
post #6 of 9 Old 06-23-2013, 11:02 AM
the baconator
Quoted: 149 Post(s)
yes that's the one
post #7 of 9 Old 06-23-2013, 11:53 AM
Quoted: 53 Post(s)
Why not contact AE tech support and get the program working right, since you've already spent money on it? It should always at least throw a P1111.
madpogue is offline
post #8 of 9 Old 06-25-2013, 04:05 PM Thread Starter
Ok I finally got it to work, I had to change the setting to Non OBD-II, and now it works great, I got the PO500 speed sensor code. At least now I know where to start looking
post #9 of 9 Old 06-25-2013, 04:14 PM
the baconator
Quoted: 149 Post(s)
glad you figured it out.
