Fuel Tank Upgrades - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-28-2008, 12:12 PM Thread Starter
Transmission or Injectors
lwillson's Avatar
Fuel Tank Upgrades
Good Day
Has anyone ever done any mods to increase the fuel capacity of an OBS truck, besides the rear tank/bronco tank switch?
I dont really want to give up much space in the truck box itself, because I do usually have a fair amount of stuff in it, and I would rather keep the spare tire mounted underneath the truck, so that pretty much makes the tank swap for the front tank my only option.
I have seen the transfer flow midship tanks (Ford pickup replacement tanks), but I am not really enthusiastic about spending $700 on a tank.
I have been contemplating getting a main frame mount tank from a newer truck and switching the front tank on my 96 to end up with a larger tank. I realize there might be some fun electrical work to get the pumps to work and guages, and a bit of steel fabrication to get the mounts to work.
If I can get a tank from a 97-03 ford , the pump pressure should be the same, its just a matter of getting the wiring straight.
Is there any obvious reasons other than amount of work required why this swap wouldn't work?
lwillson is offline
post #2 of 7 Old 03-29-2008, 06:15 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Some people use Bronco tanks to replace the rear tank. It holds about 33 gallons, I think. Our rears only hold 20.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #3 of 7 Old 03-29-2008, 06:30 PM
DunesRunner08's Avatar
I know you said you're not enthusiastic about the Transfer Flow tanks, but I have a Titan Tank thats 60 gallons and I love it. 600 miles to a tank is great, $240 to fill though is kinda tough though, lol
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #4 of 7 Old 04-05-2008, 07:47 PM Thread Starter
lwillson's Avatar
I am starting to think I might go with an in box tank, and build a deck for the back for hauling the quads or the sleds.
Has anyone on here ever been stopped by the DOT or whoever enforces proper auxiliary in box fuel tanks? Has anyone ever received a ticket for a gravity flow feed from the auxilary to the main tank?
lwillson is offline
post #5 of 7 Old 04-05-2008, 08:15 PM
Jmaccal's Avatar
Get an Excursion tank they hold 44 gals.
Jmaccal is offline
post #6 of 7 Old 04-06-2008, 10:18 AM
gnxtc2's Avatar
Quoted: 2 Post(s)
But would it fit in an OBS????
Billy T.
gnxtc2@aol.com
'97 Black F250HD SC 3.55s
Punisher trans, PI Converter, 6.0 cooler
Dana 60 RSK w/ V & C SD springs
PIS 175/80s, Honey Badger Jr, Comp910s,
Smith Bros Pushrods, ARPs, Fluidampr, IC, E-Fuel
3" Plenums, CJC Traction blocks,
HFHV IDM, T4/BASB, Tuned by
251K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
gnxtc2 is offline
post #7 of 7 Old 05-22-2008, 09:29 AM Thread Starter
lwillson's Avatar
I have been looking at the Transfer Flow and Aero tank midship replacement tanks. Both companies only make a front replacement larger tank for the long box, and I require one for a shortbox. Does anyone have one of these tanks on a long box?
I would like to know the difference, I think there is a frame crossmember in the way on the CC SB.
lwillson is offline
