HELP antifeeze in oil - Ford Powerstroke Diesel Forum
Old 03-28-2008, 09:09 AM
I have antifreeze in oil, but only a little above the full mark on the oil dipstick.
A compression test showed that it was not a head gasket. What could my problem be??
Old 03-28-2008, 09:27 AM
PMR = JUNK
what year is your truck? any mods?
Old 03-28-2008, 11:37 AM
1995 250 no mods
Old 03-28-2008, 11:40 AM
Desert Shield/Storm Vet
Hmm not sure other then a cracked block or cavitation caused you to wear through the liner. The oil pressure should be higher then coolant pressure so I don't think it would be an oil cooler issue, but Im not sure
Old 03-29-2008, 07:19 PM
lukecline
Guest
Posts: n/a
Your oil cooler is probably the culprit. There is 2 gaskets and 4 O-rings that caused the same problem on my buddies truck.
