Need some advice.... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-21-2013, 08:11 PM Thread Starter
Hey guys been awhile since I've been on here.......Afghanistan. Anyway, I,m thinking about putting a Intercooler/air to air/charge air cooler (what ever you want to call it) on my 97. It has a cold air intake and exhaust thats it, no tuner.....nothing. Basically stock. Will there be a noticable gain? In cooler weather the truck runs Soooo much better. I know cooler air means denser air, which means more air in the motor. If I go this route it'll get a tuner, nothing heavy just a little bump up. Opinions? Comments? Thanks guys...Bob
97 1 ton (real truck) and 06 2500 cummins ( it's a cummins thing, NOT A DODGE thing LMAO)
BOB1997 is offline
post #2 of 7 Old 06-21-2013, 08:30 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
If you are stock, you probably won't notice much difference in power (actually may notice more turbo lag). The cooler denser air is more of a factor in gas engines. The big benefit for the diesels is being able to keep your exhaust gas temps down, especially when running a chip or larger injectors and towing. It allows you to actually use the extra power you have before backing out of the throttle due to high EGTs. Cheers!
Patrick Feeley is offline
post #3 of 7 Old 06-21-2013, 08:39 PM Thread Starter
I didn't even think about turbo lag...... thanks for the reminder. So I assume you dont have a CAC?
BOB1997 is offline
post #4 of 7 Old 06-21-2013, 08:42 PM Thread Starter
Ignor last question....just saw your sig. I/C mounted, not plumbed
BOB1997 is offline
post #5 of 7 Old 06-22-2013, 12:29 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It helped me a lot while towing, but I'm chipped on the f250, and no gauges in my f350 to know much of a difference, but I really like how much longer I can keep in the throttle with a load and climbing hills, but yes you will notice more lag, and a slight loss in boost, I only lost 3, but she does fine with the split shots and tw tunes
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 7 Old 06-22-2013, 03:29 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
get the chip first and the IC only if you tow alot or you step up injector sizes
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 7 Old 06-27-2013, 08:56 PM Thread Starter
Those are some good lookin trucks!
BOB1997 is offline
