Twin trans coolers - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-21-2013, 05:11 PM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
Twin trans coolers
Ok. So i have another small trans cooler laying around and was wondering if I could run my stock small trans cooler that is already on the truck then run from it into the other small cooler i have and get the same effect as just adding a bigger cooler. Will there be any problems with running two coolers?
Thanks, Austin
Austin
1997 f250: mbrp 3in downpipe 4in side dump exhaust, diy 6637 intake, TW custom tuned 6pos chip, wicked wheel 2, rough country 4in lift, dana 60 swap, led dash lights, explorer overhead console, LED tail lights, dual trans coolers, SD fog lights, 08 rear diff cover, diy efuel, 20" racleline wheels with 35" firestone destination mt's,lots more little things
Nonturbo is offline
post #2 of 13 Old 06-21-2013, 07:26 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
The pressure drop may be more than a single bigger cooler. You might want to do a flow volume test after installing if you do it. Cheers!
Patrick Feeley is offline
post #3 of 13 Old 06-22-2013, 04:02 AM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
How would I do a flow volume test? And thanks for responding quickly
Austin
Nonturbo is offline
post #4 of 13 Old 06-22-2013, 04:21 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
you can run two austin, Hank runs two stock 7.3 coolers on his with no problems. A flow test is easy, take the return line, put in in a gallon jug, when you start the truck, it should pump a quart or two in less than about 8 seconds if I remember the time correctly. where you been man??
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #5 of 13 Old 06-22-2013, 06:04 AM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
Working but I've got a set of wildman tunes on the way hopefully and figured I should start looking into keeping the tranny cool. So this is what I've got.
Stock
New ( bigger than I thought it was gonna be)
So would I be good with just the new one? It's not as thick as the stock one but I feel like it would cool much more
Austin
Nonturbo is offline
post #6 of 13 Old 06-22-2013, 05:09 PM
Doesn't Even Care
Quoted: 69 Post(s)
It's all in the number of rows the cooler has. The newer one may be larger, but it won't cool as well as you want it to I don't think because of it only having 6rows. Ive got the stock cooler off mine you can have(pay for shipping) and you can connect your stock one in line with mine and it would do better. Flip one upside down and have it above the other one. Feed line from trans into one, come out of that one and go directly into thesecond one and then come out of that one and go back to the trans.
Sent from AutoGuide.com App
Nick
"The Mistress"
post #7 of 13 Old 06-22-2013, 07:41 PM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
Well my stock cooler is only 2 rows so I figured the 6 row would be 3 times as much but I may still run from my stock into my new one. How many rows is your stock trans cooler?
Austin
Nonturbo is offline
post #8 of 13 Old 06-22-2013, 08:12 PM
95redrifle's Avatar
Quoted: 4 Post(s)
I ran two coolers on my old truck with no problem. I kept the stock one and this one http://item.mobileweb.ebay.com/viewi...d=260820886096
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #9 of 13 Old 06-23-2013, 06:03 AM Thread Starter
Nonturbo's Avatar
Quoted: 4 Post(s)
Yeah I'm gonna run my stock one plus my new one. I'll be sure to test the flow though.
Austin
Nonturbo is offline
post #10 of 13 Old 06-23-2013, 09:46 AM
Doesn't Even Care
Quoted: 69 Post(s)
My stock one from my Superduty is 9 rows
Nick
"The Mistress"
