Importance of High Pressure Cross Over - Ford Powerstroke Diesel Forum
post #1 of 25 Old 06-21-2013, 02:48 PM Thread Starter
KS_
Quoted: 22 Post(s)
I was wandering what the importance might be of a HPX. Riffraff diesel offers one for 60 odd dollars. I'm pretty much stock for now but I heard it can make the idle sound a lot better. Does it do much more?
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #2 of 25 Old 06-21-2013, 05:07 PM
Wink
HPX MODE.
This hose is used to bridge the 2 high pressure oil rails in the heads that feed the injectors on the 7.3L Powerstroke.
The installation of this hose will typically smooth out rough idles as the ICP can now sense the pressure in both heads, quiet the engine, as well as provide improved oil flow to the injectors.
This kit is intended for installation on a power stroke engine to ensure that the high-pressure oil rails receive the same amount of high-pressure oil from the high-pressure oil pump. The result of installing this kit includes, but is not limited to, a quieter running engine, smoother idle, and more responsive throttle. This kit is recommended to all power stroke owners from model year 1994 through and including the 2002 model year.
This kit will NOT eliminate what is commonly called “cackle” or “idle knock”. One side effect of this kit after installation is that the engine runs quieter. This allows you to hear other potential problems in your engine that were previously covered up by engine noise.
The cylinder #8 tends to get less oil. The firing order is 1-2-7-3-4-5-6-8. Because 6 & 8 are both on the same side 6 uses the oil pressure and then 8 fires before the pressure has time to recover, with the crossover line some of the pressure bleeds over from the other head to assure that 8 has as much pressure as possible.
The problem with the #7 injector was on the superduty trucks with their dead head fuel systems. The #7 would get shortchanged on fuel and would "cackle"
CELAYORK is offline
post #3 of 25 Old 06-21-2013, 05:16 PM
c69ss396's Avatar
dieselsite actually recommends removing it if it is installed when you install the adrenaline HPOP.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 25 Old 06-21-2013, 05:44 PM
dr.deere's Avatar
Quoted: 19 Post(s)
I have it on both of my trucks I didn't notice much of a change on my 94. It took maybe 30 % of the idle hop out and that's it just as loud as before
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #5 of 25 Old 06-21-2013, 05:55 PM
Arrow
That is correct.
CELAYORK is offline
post #6 of 25 Old 06-23-2013, 06:34 AM
PSDTV21's Avatar
I've also heard instead of buying new lines you can remove the spring check valves and it does the same thing
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #7 of 25 Old 06-24-2013, 09:11 AM
Lightbulb
I also have read that but IIRC the OBS dont have that spring check valves, maybe somebody corrects me.
CELAYORK is offline
post #8 of 25 Old 06-24-2013, 10:48 AM
c69ss396's Avatar
yes the obs's have the check valves in the HPOP
c69ss396 is offline
post #9 of 25 Old 06-24-2013, 10:53 AM
Thumbs up
Ah, OK, thanks.
CELAYORK is offline
post #10 of 25 Old 06-24-2013, 01:25 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
That's dumb.......
CT Performance, Inc. is offline
