help on front end on f350 4wd steering - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-20-2013, 09:38 PM Thread Starter
i just bought a 97 f350 4wd. i noticed it steered alittle funny compared to my 97 2wd dually. after looking it over the panhard bar behind axle needs bushings. no big deal. but as we were turning the wheels back and forth the drag link and tie rods are rotating front to back before it steers. all steering tie rods and pitman joints are tight. could something be bent causing this? anyone ever seen this thanks
car23 is offline
post #2 of 7 Old 06-21-2013, 06:23 AM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Does the truck have a lift? What you can do is rotate one tie rod forward and the other one back. It won't get rid of it completely but it will help.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 7 Old 06-21-2013, 07:03 AM Thread Starter
no lift stock do u know the part number for the bushings by chance on that track bar
car23 is offline
post #4 of 7 Old 06-21-2013, 07:29 AM
Quoted: 82 Post(s)
these should be it http://www.summitracing.com/parts/mo...50?prefilter=1
Jack
322000 miles
post #5 of 7 Old 06-21-2013, 08:14 AM Thread Starter
thanks that is what they ordered for me at oreillys. but there was 2 more numbers so they ordered them all. kind of vague on the actual name. im trying to find a diagram on front end parts now
car23 is offline
post #6 of 7 Old 06-21-2013, 08:34 AM
c69ss396's Avatar
both of mine do the same thing, its annoying especially the noise they make. I'm told they make a bushing that goes between the knuckle and the tie rod end that limits the movement...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #7 of 7 Old 06-21-2013, 08:19 PM Thread Starter
i will check into that bushing. i will make something up. i work in a machine shop so i will c if what i come up with
car23 is offline
