Can a Powerstroke have retarded timing? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-20-2013, 06:47 PM Thread Starter
I don't think it is but I figured I'd ask because I have symptoms like what I've seen in IP days with retarded timing (white smoke, black smoke on acceleration and at times slight black while cruising, and a raw fuel smell). The only thing that doesn't seem like retarded timing is it starts fast and smooth.
I ran this thing on WMO and the smoke started slightly after but I want to check all my options. I'm pulling the injectors and have already checked compression.
nicksorenson is offline
post #2 of 2 Old 06-21-2013, 06:28 AM
Quoted: 85 Post(s)
Feedback Score: 4 reviews
No it really isn't possible. But a messed up cps can do odd things. You should do a cylinder contribution test and injector cutout test before pulling things apart
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
