MY HALF *** INTAKE, SAFE OR NOT??? - Ford Powerstroke Diesel Forum
Old 03-27-2008, 11:01 AM
Send a message via AIM to kx592
Question MY HALF *** INTAKE, SAFE OR NOT???
Well i figure i would try something temporarily untill i get a K&N intake. ill post the link to the picture at the bottom. do you guys think this is a safe idea or will to much bad **** get into my air box or possibly my motor. I know it wont give me much performance at all but it should let it breath at least a little more. what do you guys think.
0327081439.jpg - Image - Photobucket - Video and Image Hosting
let me know if the link doesnt work for w.e reason. thanks guys i appriciate it!!
Old 03-27-2008, 11:06 AM
AJF AJF is offline
Thats slick but there are a lot of people on here that are going to tell you to stay away from K&N. Dryflow is always good and others will chime in with their opinions too
Old 03-27-2008, 11:08 AM
lifetime member
stay away, stay away, stay away!
Old 03-27-2008, 11:10 AM
OK i get the point BUT MY QUESTION IS---is what i did there ok??
Old 03-27-2008, 11:12 AM
id give ya some input but im not really sure what im even looking at
Old 03-27-2008, 11:14 AM
Its the intake for the stock setup. It had a long tube that went all the way to the front of the hood which limits the intake ALOT so i poped the extension off so its straight air into the box.
Old 03-27-2008, 11:15 AM
Why dont you just go buy a big napa filter, some pipe or pvc, remove your entire air box, then clamp your new stuff into place and you will be running the same setup as 50% of the people on this site. Its almost as easy as what you did in that pic... and cheap.
Old 03-27-2008, 11:16 AM
oh. ok now i see it. well as long as their is no possible place for air to get in around the filter you'll be ok. If air does get in at some point past the filter your in for trouble
Old 03-27-2008, 11:17 AM
yea i know but do you guys think there is to much room for dirt.water. (bad stuff in general) to get in the box and be sucked in the motor?
Old 03-27-2008, 11:18 AM
i myself would not even consider running it, do what was said above and get a napa filter and put that on. more air and better filtering!!
