lets talk tires! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-19-2013, 12:03 PM Thread Starter
vandy's Avatar
lets talk tires!
Ive currently got a set of firestone transforce HT's 235/85/16s that where on the truck when i bought it. my tread is about 50% but the side walls have looked better. They look like they are starting to dry rot.
my questions are 1. should i worry about this right now? im not towing any loads, just DD'ing this pig right now. My buddy tells me these tires have really thick rubber and i have nothing to worry about. im trypically pretty safety conscious. but every time i see them i second guess driving it.
2. my longer term plan is putting about 3 inches of lift on her. whats about the biggest tire i can run on her with the height shes at now? I may end up going with some used tires, then go larger wheels and tires later.
im already tire poor right now, having to buy a new set of 305/35/18s for the car, now possibly for the truck. when it rains it pours right
vandy is offline
post #2 of 7 Old 06-20-2013, 01:53 AM
jjones96's Avatar
If they are load rating E tires they have a very thick sidewall so not much to worry about if its not to bad.
As for tire size on a stock height 250. 285/75 r16 is about all u can go without rubbing the bumper with a 4 inch lift 315/75 r16 which is a 35 basically will fit without rubbing
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #3 of 7 Old 06-20-2013, 04:05 AM
erics diesel's Avatar
I have 315's on my truck and only had to shim the bumper out about a half inch
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #4 of 7 Old 06-20-2013, 04:13 AM
jjones96's Avatar
Is it a 350 Eric?
The STROKE
7.3 DI T444E.
TS 6 Postion chip
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
The work truck
C&M Flatbed
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #5 of 7 Old 06-20-2013, 04:22 AM
Nope 250 with ttb and factory overloads
post #6 of 7 Old 06-20-2013, 04:30 AM
heres a pic of the front
post #7 of 7 Old 06-20-2013, 08:45 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
4x4 and 4x2 have about a 4" difference in height stock on f350's biggest you can go is about a 31-32" tire, without issues, on a 4x4 you can go about a 34 with little issues, I've done this on a 2wd and a 4x4, stock height 350 suspensions
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
