Opinions about oil... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-18-2013, 08:02 PM Thread Starter
Not trying to start a flame-war, I just want to get people's opinion on DELO 15W-40...
Those who have tried it, would you recommend it?
Those who hate it...why?
Thanks!
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #2 of 11 Old 06-18-2013, 08:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've used it, but in a pinch, it's chevron brand, not terrible not great, price is decent
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 06-19-2013, 06:42 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 51 Post(s)
I use it too, not great but not bad. Under long constant loads it does seem to burn through its anti-foaming agent in several hundred miles.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 11 Old 06-19-2013, 09:47 AM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
I have used it almost exclusively for 243,000 miles(just a couple oil changes using Valvoline). I still have original HPOP, injectors, etc...
In my opinion it is a very good oil for the price.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 11 Old 06-19-2013, 10:11 AM
judgesblind's Avatar
Quoted: 11 Post(s)
That's all my truck has run for 224k miles and haven't had any problems. Seems to be a good oil
Sent from AutoGuide.com App
Clint
96 F-250 4x4 ECLB
Current mods: DIY 6637, CCV mod, gauges, 3" DP to 4" exhaust, 6 pos chip, E-fuel, D60 swap with PMF 2.25" RSK
judgesblind is offline
post #6 of 11 Old 06-19-2013, 12:55 PM Thread Starter
OK...how about "Delvac" ?
Qwazert is offline
post #7 of 11 Old 06-21-2013, 11:45 AM
There is no bad oil as long as it is the correct oil for the application. That is MY opinion. You will never find evidence of a rash of engine failures that lead to the use of Brand X 10W-30
Everybody has that oil which floats their boat...
A buddy of mine administers the program for a major car manufacturer where they test oils. a lot of oils, that may be used in their cars and trucks. He stated that all oils are very close to being equal. The differences don't start to show themselves until you start to really push the envelope such as race engines or extended drain intervals (15 to 20K miles).
Oil filters on the other hand... I do believe there is a difference. So does my engineer friend.
My 2 cents,
Tom
Ozonkiller is offline
post #8 of 11 Old 06-21-2013, 12:16 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
I use Rotella 15W-40 primarily because I can get it for $60 for a five gallon bucket, it works as advertised, and then I get a free 5 gallon bucket. Helps defray the cost of the Wix oil filters.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
post #9 of 11 Old 06-21-2013, 01:43 PM
nra1ifer's Avatar
I have been using Tractor Supply Co's Traveller 15W-40. I get it for $49.99/5-gallon pail. Analysis by Blackstone on every change and doing fine. I get my Motorcraft oil filters at Walmart, something like $9.50 each. I added an FS-2500 bypass fllter, not for extended drain intervals, but for the excellent filtration. I still change the oil at 4K-5K intervals.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
post #10 of 11 Old 06-22-2013, 07:01 PM
PSDTV21's Avatar
I've used Rotella T 15w-40 and I'm starting to not like it. Yeah it's oil and like stated before all oils are pretty close, but it's cheap and everywhere. In my mind that makes me wonder how they make money on that, less quality. So with that rant I will probably use Valvoline Premium Blue endorsed by Cummins or Rotella T6 synthetic
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
