Sagging bumper disease - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-18-2013, 03:15 PM Thread Starter
d7es3l's Avatar
Almost every OBS I see has a sagging bumper... including mine so, what is the permanent solution to this? If there is one? Thanks!
d7es3l is offline
post #2 of 8 Old 06-18-2013, 04:18 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
There are some stiffener brackets that are supposed to help. There was a post on it in one of the forums on another site (I will have to search for it). Cheers!
Patrick Feeley is offline
post #3 of 8 Old 06-18-2013, 04:21 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Your bolts are loose, back them off a bit, have some help and push it up, tighten the piss out of it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 8 Old 06-18-2013, 04:43 PM
Quoted: 15 Post(s)
Here's the thread from the "Nation": Sagging front bumpers - PowerStrokeNation : Ford Powerstroke Diesel Forum
and in case this forum won't show it, here's the LMC page that has the reinforcement brackets (which come in the mounting kit or sold individually). Factory parts are F2TZ-17A792-A for right and F2TZ-17A792-B for left.
Cheers!
post #5 of 8 Old 06-18-2013, 04:49 PM Thread Starter
d7es3l's Avatar
Thanks guys! I appreciate it!
d7es3l is offline
post #6 of 8 Old 06-18-2013, 05:14 PM
dazed01's Avatar
I put on a gage front bumper and it cured the sagging bumper.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #7 of 8 Old 06-19-2013, 06:48 AM
superduty4x4's Avatar
Its kinda sad how cheesy the front bumper attachment is on these trucks. Nice thick steel plate that bolts to the frame, but then it bolts to a thin chrome plated bumper with no braces or reinforcements...
Those $20 braces from LMC look like the way to go. I may have to give that a whirl on the OEM bumper I have waiting to go on my truck.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #8 of 8 Old 06-19-2013, 08:42 AM
rolsmojave3's Avatar
I had one with a twist in it, couldn't get it right with new brackets. The RH side was down, so I shimmed the RH lower mount to correct it. It's keeping a straight face so far.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
