Fan clutch help - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-17-2013, 08:14 PM Thread Starter
LilBit 4x4's Avatar
Fan clutch help
Hey all. Tried for a good hour to get the fan clutch out with the tool I rented from autozone. I could not get it to budge. It was rounding off the nut. Yes, I was turning it in the correct direction (right hand thread). Any suggestions ?
1995 F350 7.3L DI Turbo Crew Cab Long Bed
Project Truck in the Making
<3
Nicole
LilBit 4x4 is offline
post #2 of 13 Old 06-17-2013, 09:05 PM
asian195's Avatar
Quoted: 2 Post(s)
Hold the pulley some how, and smack the fan tool with a big hammer. That's the only way I know how..
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #3 of 13 Old 06-18-2013, 07:46 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Agreed, some dillholes locktight the fan nut to the water pump.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #4 of 13 Old 06-18-2013, 07:53 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Those clutch fans are a PITA!
2000-7.3L is offline
post #5 of 13 Old 06-18-2013, 08:05 AM
Quoted: 3 Post(s)
The autozone rental tool is a piece of s$%t. I bent the wrench open when I did mine not too long ago. I had to rig it up so the tool holding the bolts was wedged in the truck so I could get two hands on the wrench turning the nut. Hope it works out for you.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #6 of 13 Old 06-18-2013, 08:05 AM
Quoted: 3 Post(s)
What part of FL, maybe someone local can give you a hand if necessary.
2000 DRW CC 7.3
post #7 of 13 Old 06-18-2013, 08:09 AM
2000-7.3L's Avatar
double wrench it! Watch your knuckles tho!
post #8 of 13 Old 06-18-2013, 01:52 PM Thread Starter
LilBit 4x4's Avatar
I'm in New Smyrna Beach... about 30 minutes south of Daytona Beach on the East Coast. I used to live by Hudson though, in New Port Richey lol!
I actually tried this with two people and we had trouble. We tried cramming the part that holds the bolts in there so it wouldn't budge but it still didn't work.
<3
Nicole
post #9 of 13 Old 06-18-2013, 02:47 PM
Quoted: 3 Post(s)
Sounds exactly like mine went when I replaced my water pump. I double wrenched it as another member stated before for added leverage, a piece of pipe would be safer for the knuckles though.
2000 DRW CC 7.3
post #10 of 13 Old 06-18-2013, 05:32 PM
Micko's Avatar
Quoted: 4 Post(s)
Mine had red locktite on it so I had to apply heat. It was tricky getting the torch in there but it woked. Just applied heat to the nut. Sounds like you're getting the leverage you need, just add heat.
Micko is offline
