how to tell a bad fuel injector w/ valve covers off - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-17-2013, 05:47 PM Thread Starter
i'll be removing my valve covers soon to put new glow plugs in and some other stuff. While i'm in there, is there any way i can tell if i have a bad fuel injector?? thanks
slapshot1540 is offline
post #2 of 2 Old 06-17-2013, 06:56 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
You can run the engine with the covers off and check the oil flow out of the injector deflector spouts. They should all be about the same. If one has significantly less, that would indicate a bad injector although it could be a bad solenoid, a loose poppet screw, or something else. I guess you could also have a bad injector with good oil flow, but the above is the only way I know. Cheers!
Patrick Feeley is offline
