Valve cover/fuel injector harness - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-17-2013, 01:32 PM Thread Starter
Hey guys, just got a 1997 f350. I'm about to do the glow plugs on it and replace the valve covers because they're leakin a little bit. I saw these Dorman valve cover gaskets with the fuel injector wiring harnesses. Dorman® OE Solutions™ 615-202 - Diesel Valve Cover Gasket | O'Reilly Auto Parts would these be a good idea to get?? the truck has 260,000 miles. It does run just a little rough and gives me some trouble starting in the morning, followed by white smoke, but seems to run pretty good.
slapshot1540 is offline
post #2 of 12 Old 06-17-2013, 02:18 PM
Although I'm no expert on this...I'm interested in the replies. I have 2 connectors that are burnt out, so I'm down AT LEAST 2 glow plugs for cold starts...white smoke, etc...
Will be watching this thread...
97 F250 PSD...6637 Filter upgrade...3" Diamond Eye DP...DFuser EBPV eliminator...Improved "Blue" CPS...
Qwazert is offline
post #3 of 12 Old 06-17-2013, 02:18 PM
I've been told ya don't want doorman unless you can test them but that's what I'm getting ready to put on mine
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #4 of 12 Old 06-17-2013, 02:27 PM
erics diesel's Avatar
I used Dorman ones on mine and have had no issues with them in over a year
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #5 of 12 Old 06-17-2013, 05:44 PM Thread Starter
i may just buy the felpro gaskets and get the dorman harness
post #6 of 12 Old 06-17-2013, 07:48 PM
Gasket isn't the problems with dorman its the uvch felpro is a lot more dough for no benefit.
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #7 of 12 Old 06-18-2013, 01:53 AM Thread Starter
what is uvch?
post #8 of 12 Old 06-18-2013, 02:12 AM
Colin7.3's Avatar
Originally Posted by slapshot1540 View Post
what is uvch?
Under valve cover harness
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #9 of 12 Old 06-18-2013, 05:19 AM
Quoted: 54 Post(s)
Dorman gaskets DO fail out of the box at times. At least one guy had a problem with one shorting to ground, but only when he torqued down the cover bolts.
madpogue is offline
post #10 of 12 Old 06-18-2013, 05:24 AM
So did he initially over torque the BC then try correct torque and possibly pinch something on first torque attempt
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
