AC blower motor need to be on in ACC - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-17-2013, 06:55 AM Thread Starter
mkeith54's Avatar
Sorry I posted this in the exterior forum, Mod can you delete if I can't figure out how.
I had a Viper remote start installed and it seems to only power accessories fuses and not Run fuses. The AC Compressor is on an ACC fuse and the blowers is on a run fuse. Did my dealer install it incorrectly, or do I need to relocate the blower fuse to the ACC position.
I need the Ac to run while the truck idles to keep my husky cool if we stoop for dinner while on the road. Up until the viper install I just locked to key on the truck and figured no one would mess with that big of dog sitting in the drivers seat. Now that I have remote start I'd like to be able to take the key out. If anyone has this setup let me know how yours works. Thanks
__________________
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #2 of 2 Old 06-17-2013, 07:24 AM
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Depending on which Viper alarm you have it may have a additional output that could be used to drive the ac system. I would take it to a reputable shop that puts alot of those alarms in and explain to them what you want. I used to do alarm installs and have ran into that problem before. Like I said a reputable shop should be able to do it for under 100.00.
jim
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
