Passenger side exhaust manifold - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-16-2013, 10:24 AM Thread Starter
01Crewcab7.3's Avatar
Can it be taken off of the engine without taking the engine out of the truck? My truck will not make more than 5 lbs of boost, and my EGT's are through the roof even when empty. So I made a boost leak tester and hooked it up. I could hear air rushing out on the passenger side of the engine. When you put your hand down near there you could feel a cold patch in the heat so I am thinking the manifold may have a crack in it or something. So back to my initial question, I know it will be a huge PITA but is it possible? I plan to soak all of the bolts in PB for several days before I attempt removal. Thanks for any insight guys.
-Tim
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #2 of 8 Old 06-16-2013, 12:29 PM
If you did a boost leak test, are you positive it's not the intake plenum? Maybe try the test with some diluted dish soap in a spray bottle and pinpoint the leak.
Rusty
rusty1161 is offline
post #3 of 8 Old 06-16-2013, 01:10 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i don't know but i am interested to know. i know you can get the drivers side out easily
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 8 Old 06-16-2013, 01:24 PM Thread Starter
Rusty
I am like 95% positive. I had a spray bottle and checked the boots, plenums, my boost gauge fitting, everything. With where the manifold is I could not see it well enough to test with the soapy water.
Tim
post #5 of 8 Old 06-16-2013, 01:25 PM Thread Starter
With my luck it will be incredibly difficult and I will break off at least one bolt in the head haha.
Tim
post #6 of 8 Old 06-16-2013, 01:29 PM
the baconator
Quoted: 141 Post(s)
that's how it goes. though on my truck i had a broken bolt and it was very easy to get out of the head with a pair of vice grips.
post #7 of 8 Old 06-16-2013, 01:39 PM
rolsmojave3's Avatar
It's also not that bad to pull the engine if it comes down to it.
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #8 of 8 Old 06-16-2013, 01:53 PM Thread Starter
I'm half tempted to just pull it anyway. It would be a good chance to refresh it a bit and clean the engine bay and motor. Fix any leaks and put it back in. I figure just a weekend and the truck would be running again.
Sent from AutoGuide.com App
Tim
