uvch cause no start? - Ford Powerstroke Diesel Forum
post #1 of 52 Old 06-13-2013, 11:34 AM Thread Starter
Connectors that got to the uvch are fried on both plug ins on drivers side could this be my no start?
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
post #2 of 52 Old 06-13-2013, 12:02 PM
theforeman57's Avatar
Quoted: 4 Post(s)
From all that i have read, yes, that could cause hard starting/ sometimes no starts. If i am correct, the two outer pins control two cylinder's glow plugs, then the two in from those control the injectors for those two cylinders, and the center is a common ground, so these could very well contribute to your no start. it is also not uncommon for the two plugins on the inside to start arcing out and melt as well. Hope I could Help!
Axel.
Axel --> 16yo
96 CCLB srw. built E4OD, Diy E-fuel, Autometer gauges
4:10 lsd, Toyo M55 on stock steelies
Future plans include diy Traction bars, and zf5 swap.
theforeman57 is offline
post #3 of 52 Old 06-13-2013, 12:10 PM Thread Starter
Well I decide instead of just replacing those connectors I can get the whole uvch and two pigtails for 58 bucks in a kit so I'll probably just do that
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #4 of 52 Old 06-13-2013, 12:16 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
As long as it's not the Dorman kit.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 52 Old 06-13-2013, 12:20 PM Thread Starter
What's wrong with dorman kit?
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #6 of 52 Old 06-13-2013, 12:27 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
So it is the Dorman kit
They are known for poor performance as the fittings are concerned. Things like the pins in the pigtails not actually touching any metal and causing the same issues but from a different source after install. Pins not tight enough to make good connections under heat to the VC plugs. Stuff like that.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 52 Old 06-13-2013, 12:33 PM Thread Starter
Great lol what do you suggest then budget here
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #8 of 52 Old 06-13-2013, 12:38 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Some Dorman kits are perfectly fine. Use a meter and test everything before you do the install. Easy job and if things look good you should be all right.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 52 Old 06-13-2013, 12:41 PM Thread Starter
As long as it gets me through the summer I'm fine this winter hopefully I'll get to pull the motor as planned and freashen it all up paint and all
Ben
6637
4" back to 7" stack
140V IDM Mod
Custom tow mirrors
95350PS is offline
post #10 of 52 Old 06-13-2013, 12:46 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Sounds good, so you're going to keep it? Any new pics of you and your work truck?
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
