1995 F-250 7.3L Powerstroke routine maintenance - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-12-2013, 06:47 PM Thread Starter
Cwilson1's Avatar
I am new to the Diesel world and I just purchased this F250 with the 7.3l 4x4. I am going to use this truck mainly for towing my 5th wheel. The truck is already outfitted with Firestone airbags and both tow behind and in the bed hitches. Unfortunately I don't have any of the maintenance records from the previous owner(there was only one). What's the consensus here on what I should do to the truck to get it ready? I was personally thinking of changing out all the fluids and filters. I really am not to sure though so any advice is appreciated.
Thanks
1995 F-250 7.3L 4x4
Cwilson1 is offline
post #2 of 16 Old 06-12-2013, 07:25 PM
WD40's Avatar
Quoted: 35 Post(s)
I think you are on the right track by changing out all of the fluids and filters. You
didn't say how many miles are on the truck? I think it would be a good ideal to catch
a pint of the engine oil and have it tested for wear and to see what parts are in the
oil. Most will tell you to stay with only MotorCraft oil and fuel filters for your Ford, and
any good Diesel oil will do but I still like Shell RotellaT 15 W 40. If the hose and belt
have not been changed in the last year or two I would change all of them out. It's no
fun being stuck on the side of the highway with your 5th wheel and the wife and a
leaking water hose, or broke fan belt. Enjoy your truck, what kind of fifthwheel do you
have and where you from. Also Welcome to The Org.
Happy Camping.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #3 of 16 Old 06-12-2013, 08:02 PM Thread Starter
Cwilson1's Avatar
Thanks Doug! The truck has a 126,000 miles on it and all the hoses and belts actually look brand new. I will definitely have the oil tested does it matter if it sits in a container for a week and half before I send it in to get tested?
We just bought a Open Range 413RLL 5th wheel down in Utah and will be bringing back home to Washington State.
1995 F-250 7.3L 4x4
Cwilson1 is offline
post #4 of 16 Old 06-12-2013, 09:48 PM
WD40's Avatar
Quoted: 35 Post(s)
Blackstone Labs Does this kind of oil analysis if you need to get it done.
You just about got a new truck with only a 126,000 miles on it. That is one big trailer, sure hope your truck has 4.10
gears in it. Will you be retiring soon or is this just for weekends? Great looking rig.
Doug
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
EX-USN
Doug
WD40 is offline
post #5 of 16 Old 06-15-2013, 04:04 PM
nra1ifer's Avatar
Ditto on all of the fluids and hoses. Add the serpantine belt to the list. If you have an automatic transmission, I would suggest adding a larger transmission cooler (like the one from Tru-Cool...... http://www.dieselsite.com/specialord...ioncooler.aspx), and a magnefine filter (More Information for ATP JX150) on the return cooling line to the transmission, and you might also think of adding an exhaust brake to the truck. I'll be adding one to my 1995 F250 PSD one of these days, getting it ready for towing a travel trailer or 5th wheel. My brother also had a 1995 F350 PSD that he hauled what had to be the biggest Lance camper they made in the bed of his truck. He said it came in very handy in hilly/mountainous areas. I'd have to look around to find the brand he used, but he really liked it. Somewhere in the $1200 range.
nra1ifer
1995 F250 Ext. Cab 7.3L PSD
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.
nra1ifer is offline
post #6 of 16 Old 06-15-2013, 04:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've seen older unused exhaust brakes for $400
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 16 Old 06-15-2013, 09:38 PM
WD40's Avatar
Quoted: 35 Post(s)
CWilson, did you get to find out what gears your truck came with, should be 3.55 or 4.10, I
don't think the 3.73s were offered in 1995. What 5th wheel hitch does it all ready have in it,
is it a 16.000 or a 19.000?
Doug
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
EX-USN
Doug
WD40 is offline
post #8 of 16 Old 06-15-2013, 09:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
3.73 wasn't offered until 99
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 16 Old 06-16-2013, 06:52 AM Thread Starter
Cwilson1's Avatar
According to the sticker it has 3.55 and the hitch is a brand new Reese 16k
1995 F-250 7.3L 4x4
Cwilson1 is offline
post #10 of 16 Old 06-16-2013, 08:41 AM
WD40's Avatar
Quoted: 35 Post(s)
With the 3.55 gears if I were you I think I would look at getting a Gear Vendors Under/Overdrive, 4X4 Wheel Drive auxiliary transmissions.
Your truck is going to have a load for sure. Good luck and enjoy the trip.
Doug
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
EX-USN
Doug
WD40 is offline
The Following User Says Thank You to WD40 For This Useful Post:
willowswitch (11-30-2014)
