Radiator and fan install - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-12-2013, 04:58 PM Thread Starter
LilBit 4x4's Avatar
Hey all. Have a leak in my radiator so I ordered a new one. Will be here tomorrow. I also ordered the fan blades for the 6.0 bc they are lighter. It arrived today. Never did any if this before so if anyone can help and give me suggestions I would greatly appreciate it!
1995 F350 7.3L DI Turbo Crew Cab Long Bed
Project Truck in the Making
<3
Nicole
LilBit 4x4 is offline
post #2 of 4 Old 06-12-2013, 06:31 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
I forget the year of your truck (you might want to fill out a signature in your profile that has that info in it). My 94 radiator shroud was held in with 4 bolts (IIRC), while my 97 had only two (and some locating tabs on the bottom). I remove the shroud and fan/fan clutch assembly together (see below for the fan). The stock metal fan has sharp blades, so be careful with them (easy to slice yourself).
The radiator hoses are straightforward (you can drain the fluid using the drain valve on the bottom of the radiator ... there's quite a bit, so have enough/big enough containers on hand) and if you have an automatic transmission, you will need to undo the transmission lines that go into the cooler that's part of the bottom of the radiator assembly. You will probably want to find some hose, etc. to plug the lines after undoing them so you are not dripping trans fluid all over.
To install the new fan, you will want a fan clutch wrench set to remove the fan and fan clutch as a unit. AutoZone will rent you a set for free. The AutoZone set part number for a PSD is #27141 (the others don't fit). One of the wrenches will go on the big fan clutch nut, while the other will go over the 4 pulley bolts (leave the belt on too). The fan clutch is right-hand threaded (righty-tighty, lefty-loosey!). A suggestion: I like to place a big piece of cardboard between the radiator a fan when removing/installing the fan assembly to avoid possible damage to the radiator. Once the fan clutch is undone and the shroud is undone, pull them up and out together (also the same for reinstall). Hope that helps. I'm sure I left something out, but the good folks here will be glad to point that out (... I mean fill in the blanks)
Cheers!
Patrick Feeley is offline
post #3 of 4 Old 06-13-2013, 07:23 PM Thread Starter
LilBit 4x4's Avatar
Cheers!
Thanks so much for this in depth how to! I appreciate it so much. I am just replacing the fan, not the whole assembly though. So, I don't think I need to remove the fan clutch as well?
<3
Nicole
post #4 of 4 Old 06-13-2013, 07:38 PM
Undead Member
gaspipe's Avatar
Quoted: 7 Post(s)
I've never pulled a radiator w/o having pulled the fan clutch, fan and shroud out together. I'm not sure there is room.
I have swapped fan blades to the 6.0 w/o removing the shroud (but loosened the 4 shroud bolts), but the fan clutch had to be removed to make it work. It's tight work up in there.
~Bruce~
'95 F250 4x4 ECLB 300k - ZF5, Southbend, 4.10, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 4" exhaust, BFAF, 6.0 fan, 140v IDM, Autometer, MagHytec diff cover, HD ft springs, 16x8 alloys
'95 F-Superduty 4x2 CM 12' Flatbed 47k - E4OD, 5.13, Banks intercooler, van pedestal, EBPV & CCV delete, 1.0 ex housing, 3" DP, 3.5" side dump exhaust, BFAF, PHP tunes, 6.0 fan, 140v IDM, TruCool, MagHytec diff/pan, Dieselsite ext trans filter, Autometer, 180w LED bar
gaspipe is offline
