Trans Cooler help - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-21-2008, 07:24 AM Thread Starter
Chad T's Avatar
Trans Cooler help
I just purchased a Trans cooler. Should i just swap the old one for the bigger one or should you just add it on to the smaller cooler and use both? Is this possible and does it help? Does anybody know of a write-up for this? Thanks Chad
1997 crew cab 7.3
Auto, 4x4, 3.55 rear
3"to 4" exhaust
Afe II with proguard 7
TS 6 position
Quad Commander gauges
FPR shimmed
Modified IDM
TQ upgrade with BTS valvebody
Chad T is offline
post #2 of 19 Old 03-21-2008, 07:31 AM
duct tape & zip ties
bigcountrysg's Avatar
Add it, keep the oem one. Yes it is possible, take the return line from the oem cooler, hook it to the new trans cooler, then with a new piece of hose hook the new trans cooler to the old one.
I have three trans coolers on my truck.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 19 Old 03-21-2008, 10:57 AM Thread Starter
Chad T's Avatar
Thanks Big Country and did the extra cooler make a good difference in temp?
1997 crew cab 7.3
3"to 4" exhaust
TS 6 position
FPR shimmed
Modified IDM
Chad T is offline
post #4 of 19 Old 03-21-2008, 10:59 AM
Ole White
bigwhite7.3stroker's Avatar
I did the same on my truck if you can have one why not have two
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #5 of 19 Old 03-21-2008, 11:01 AM Thread Starter
Chad T's Avatar
How much of a difference in temp did it make for you Big White?
1997 crew cab 7.3
3"to 4" exhaust
TS 6 position
FPR shimmed
Modified IDM
Chad T is offline
post #6 of 19 Old 03-23-2008, 03:19 PM
Powerstroke Junkie
NCHornet's Avatar
Just make sure you do a flow test when you are all done, as you can restrict flow with to many coolers, you should see 1 quart every 15 sec on the return line.
My opinion is to by one satisfactory cooler instead of 2 or 3 smaller ones, you will get far better results. I did the 6.0 cooler before it was the popular mod to do and I could buy them all day long for $60 shipped. Running just the 6.0 cooler dropped my temps 40 degrees.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 19 Old 03-23-2008, 03:26 PM
Chrisf97305's Avatar
Send a message via Yahoo to Chrisf97305
let me ask this, are you having trouble keeping it cool???
Chrisf97305 is offline
post #8 of 19 Old 03-23-2008, 03:37 PM
Shaking the Bush Boss
CHUCK's Avatar
I thinking about doing the same thing. My trans hit 180 towing an empty 16' trailer at 70mph for about 10 moles.
Chuck
CHUCK is offline
post #9 of 19 Old 03-23-2008, 03:39 PM
If your trans is heating up in converter lock up then you have other problems, like its slipping. then a cooler will not help.
post #10 of 19 Old 03-23-2008, 03:45 PM
CHUCK's Avatar
I hope no other problems. I just went thru the trans about 10000 miles ago.
Chuck
CHUCK is offline
