spare tire size that fits the carrier? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-11-2013, 05:17 PM Thread Starter
Arcturus's Avatar
I need to get some parts for my spare tire carrier, but before I get them, does anyone know if the carrier is big enough to carry a 265/75 tire, since the OEM size was 225/75's?
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #2 of 9 Old 06-11-2013, 05:56 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
yes it will fit a 265/75-16 i have it in there now. and stock size is 235/85-16
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 9 Old 06-11-2013, 07:06 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I am pretty sure a 35 will fit in the stock carrier.
I am working on mounting a 04 SD carrier in my truck
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #4 of 9 Old 06-11-2013, 07:43 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What's the difference in an sd carrier?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 06-12-2013, 01:18 AM
Quoted: 4 Post(s)
It is a winch style. It lowers a cable from the center via the jack crank handle
post #6 of 9 Old 06-12-2013, 01:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
you going to have the input above the license plate? sounds like my wife's f-150's set up
which I still need to figure out where the damn jack is
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 06-12-2013, 07:03 AM Thread Starter
Arcturus's Avatar
Thanks guys!
Is the super duty carrier a straightforward bolt in mod?
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #8 of 9 Old 06-12-2013, 09:59 PM Thread Starter
Arcturus's Avatar
I got the part I needed to mount the spare today. What a pita getting that tire up there. I had to use blaster on the bolts and lower the driver side bolt leaving just 1 thread above the nut. Even then the 265/75 was hitting the gas shield on that side before the pass. side. I didn't want to crank it up too tight and damage the sidewall.
I think with any tire bigger than a 265 you'll need to get a bigger bolt for the drivers side at the least, the 265 max's it out. In fact I think I should but I don't want to through that again.
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #9 of 9 Old 06-13-2013, 02:28 AM
Quoted: 4 Post(s)
The SD carrier is far from a bolt in. I need to make mounting brackets for it. The rear tank is the mounting problem
