fuel gushing out from under truck HELP - Ford Powerstroke Diesel Forum
Old 03-20-2008, 10:05 AM
I parked my truck and when i was letting it idle it was gushing fuel out. When i turn the truck off it stops (so i know the fuel pump is working HAHA) I took the fuel filter out and it was draining out of the bowl. it looks like its under the bowl/filter housing. I NEED THE HELP!!!!!!!!!!!!!!!!!!
Old 03-20-2008, 10:09 AM
on the right side of your fuel filter canister there is a sensor looking thing with one wire plugged into it. the guy at the dealer said it was a fuel filter vacuum switch? where the metal mates with the plastic it leaks so check that. it happened to me a few months ago. the part is about 80 bucks here
Old 03-20-2008, 10:10 AM
Desert Shield/Storm Vet
Check and see if its coming from the drain valve. If it is its the orings.Separator Valve Rebuild Also check your fuel bowl and make sure its not corroded or rusted out on the bottom.
Old 03-20-2008, 10:16 AM
Everything under the fuel filter housing is covered in fuel. it also spattered around it. if that info helps you guys help me through this problem. how would i take the housing off?
Old 03-20-2008, 10:21 AM
Here you go, but make sure its the fuel bowl leaking before you remove Fuel filter removal
Old 03-20-2008, 10:25 AM
alright. ill check it. im gettin off line now because my boss wants the computer. any more info call my cell 17172866630
Old 03-20-2008, 01:41 PM
still doin in do you have any more suggestions?????????????????????????? i have a buddy comming with a trailer and im going to take it to my other buddy's shop. i would try and drive it but i dont want to leak out that liquid $4.29 gold.
Old 03-20-2008, 02:58 PM
So have you found where the leak is?
Old 03-21-2008, 07:06 AM
UPDATE. THere is fuel in the valley. what should i do now? i was reading some post last night and today about the valley but what do i have to do to get under the fuel filter and the hoses?
Old 03-21-2008, 07:44 AM
CHECK THE TUBE FROM THE TRANSFER PUMP TO THE BOTTOM OF THE HOUSING ALSO CHECK FOR A CRACKED HOUSING, AND ALSO MAY BE THE DRAIN VALVE AS WELL.
