Synthetic Oil - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-10-2013, 06:00 PM Thread Starter
01Crewcab7.3's Avatar
Synthetic Oil
Okay so I will be doing an oil change on my OBS this weekend. As long as I have owned it I have run Rotella 15w-40 in it with the FL-1995 Motorcraft filer. This time I plan to change to Amsoil 15w-40 synthetic.
AMSOIL SAE 15W-40 Heavy-Duty Diesel and Marine Motor Oil
My first question is, do I need to empty the HPOP reservoir as well as the pan as to not mix synthetic with conventional or does that matter. Secondly should I use an Amsoil filter or will the FL-1995 filter work?
Lastly I also plan to service the rear end at the same time (going to put an 08 aluminum cover one too) and plan to switch to synthetic. I have the 10.25 obviously with 4.10's and the door tag says its an open diff. There are 4 different options listed for the rear end oil so my question is which one should I run?
SAE 80W-90 Synthetic Gear Lube (AGLQT)
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Thanks for any help you guys can give!
-Tim
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #2 of 10 Old 06-10-2013, 06:07 PM Thread Starter
Just discovered the Amsoil Ea filters. Its pricey but I think I might run that, as I am sure it is designed for the oil. Only makes sense to me.
Tim
post #3 of 10 Old 06-10-2013, 06:18 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i didn't drain the HPOP reservoir there will still be conventional oil in the rails, so there will still be "contamination" though draining and refilling the reservoir is one more old quart out and new one in.
rear end i used amsoil 75-90 severe gear or 75-140 if you tow heavier and more often
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 10 Old 06-10-2013, 06:26 PM Thread Starter
Thanks for the info Terry. Yeah it tows almost every day now 6-10k. That is one of the reasons I am upgrading all of the fluids to synthetic.
Sent from AutoGuide.com App
Tim
post #5 of 10 Old 06-10-2013, 06:33 PM
the baconator
Quoted: 143 Post(s)
i believe the rear already has synthetic from the factory
post #6 of 10 Old 06-10-2013, 06:52 PM Thread Starter
Really? I would have never guessed.
Just realized how sarcastic that sounded.
Tim
post #7 of 10 Old 06-10-2013, 07:23 PM Thread Starter
Just out of curiosity ( I don't know much about this stuff) what is the real difference between the 75-90 and 75-110?
Tim
post #8 of 10 Old 06-10-2013, 07:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Don't matter bout old oil getting in with your new synthetic, like terry said its gonna happen, for the rear I used royal purple 75w140, I have limited slip and this keeps from adding the traction modifier too, ended up costing close to the same as amsoil plus the modifier
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 10 Old 06-10-2013, 07:27 PM
AMSOIL is compatible with conventional oils, however it will effect the drain interval. If you keep the first change on the conservative side there should be no problems. The synthetic with the Ea filter will allow extended drain intervals.
Do yourself and your wallet a favor and become a preferred customer for a $10.00 investment/six month membership you will purchase at wholesale pricing. You will make you money back and then some with this oil change.
For the gear oil, I agree with Terry. AMSOIL has an excellent vehicle look-up guide on their main web page for all recommended products. If you want a price break down between the two let me know.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
post #10 of 10 Old 06-10-2013, 07:29 PM
[QUOTE=01Crewcab7.3;5576426]Just out of curiosity ( I don't know much about this stuff) what is the real difference between the 75-90 and 75-110?
110 is a heavier/thicker grade than the 90.
Chris
