where to get oil additave to reduce foaming - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-10-2013, 04:39 PM Thread Starter
ole96stroker's Avatar
Does anyone know where I can get any additive to reduce oil foaming, I just changed my hpop and used red high temp rtv gasket maker and the truck is running real rough now and throw's icp code. thanks
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 10 Old 06-10-2013, 07:40 PM
Maybe try a better oil. You shouldn't have to "add" anything to it. It will most likely degrade some portion/property of the oil.
Chris
1984 F-350 XLT 4x4 4spd. 6.9 (project)
1996 F-250 XLT 4x4 5spd. 7.3
2001 Excursion XLT 4x4 Auto 7.3
AMSOILdealer is offline
post #3 of 10 Old 06-11-2013, 09:06 AM
What oil are you using? I use delo and mine seems to like it. Though im thinking of swapping to amsoil next oil change.
95 f250 powerstroke, zf5 with solid flywheel conversion, 3 inch downpipe to four inch diamond eye stainless steel exhaust, riffraff 6637 intake, pyro and boost gauges, and more to come
_95stroke is offline
post #4 of 10 Old 06-11-2013, 09:24 AM
erics diesel's Avatar
If you just changed your hpop then you probably have air in the system that will work its way out
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #5 of 10 Old 06-11-2013, 09:34 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I use valvoline and motorcraft with zero issues
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 10 Old 06-11-2013, 12:24 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I haven't verified these part numbers, but here you go (from my parts archive):
Antifoaming Additive (counters RTV reaction with oil)
(Fleetrite) CH1824392
(Lubrizol) 888
Cheers!
Patrick Feeley is offline
post #7 of 10 Old 06-11-2013, 02:17 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i agree with eric, you need to drive a couple hundred miles to make sure you get all the air out
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 10 Old 06-11-2013, 07:13 PM Thread Starter
I went to my international dealer and they looked at me like I was stupid haha. But I figured maybe something else was wrong since it wouldn't go over 10 psi boost and throw the icp code if I hold it to long, then going down the run it would start jumping and missing then it would blow out a cloud of blue but I ran the dog crap out of it for like 50 miles and I figured all the air would've been out after I changed the hpop. thanks
post #9 of 10 Old 06-11-2013, 07:16 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
just for giggles your not overfilled oil wise correct
We Miss you Ronnie
ZMANN is offline
post #10 of 10 Old 06-11-2013, 08:39 PM
Quoted: 13 Post(s)
Did you give them the Fleetrite part number? They should've been able to look it up easily. Cheers!
