ScanGauge II won't work for '96 which one to buy?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-10-2013, 02:15 PM Thread Starter
Woodturner Nate's Avatar
Quoted: 2 Post(s)
I'm really disappointed that the ScanGauge II that I bought doesn't work for my '96. It won't read codes. The computer seems to have a bunch of stored codes in it, but the codes it displays don't correspond to any Ford codes.
So, this leads to the obvious question; what scanner do i buy to read codes??!!!
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #2 of 10 Old 06-10-2013, 02:23 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Best..get a used Snap-on MT 2500..you can find them for $200-300
CT Performance, Inc. is offline
post #3 of 10 Old 06-10-2013, 02:27 PM Thread Starter
Quoted: 2 Post(s)
After I just dropped $160, not returnable to the seller, I don't have a spare $300 to spend. Any cheaper options?
post #4 of 10 Old 06-10-2013, 02:40 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Aero force interceptor, or a locked used edge evo
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 10 Old 06-10-2013, 03:02 PM Thread Starter
Quoted: 2 Post(s)
I see different edge evolution models. Some are programmers, some are just gauges. What does "locked" mean?
post #6 of 10 Old 06-10-2013, 03:09 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The edge evo (handheld silver box) is a tuner/code reader, locked means it was put on a truck and not used again to take the tune off the truck, so it can only be used for checking codes, it's moniters a few PCM read perameters tho, but I would not recommend it for tuning anything but a stick shift
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 10 Old 06-10-2013, 03:47 PM
c69ss396's Avatar
Auto Enginuity Scan Tool - PC Based
for $360 you will have the best scan tool, it will allow you to do any tests the dealer can do...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #8 of 10 Old 06-12-2013, 09:12 AM
ChiefRocka's Avatar
This one is pretty nice ....
Wondering if this will work on my '95 ???
John
2002 F-250, CCSB, 4" Exhaust, Stock otherwise
ChiefRocka is offline
post #9 of 10 Old 06-12-2013, 09:33 AM
Quoted: 3 Post(s)
From posts I have seen...they won't work on the OBS...Snapon's will
post #10 of 10 Old 06-13-2013, 08:10 AM
AddictedOffroad's Avatar
I use an Innova 3100e
They usually run $169 or so. It will pull current codes as well as stored codes on my 94'.
Scotty
1999.5 F350 DRW, CC, LB, A/T, 7.3L. Bank Exhaust brake, 4" Exhaust, BD power Thruster II turbo, PHP Hydra
AddictedOffroad is offline
