Next step....power - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-09-2013, 10:28 PM Thread Starter
Next step....power
Hey guys I'm relatively new to the boards but I've had my 7.3 for around a year and a half. I've done a full transmission teardown and upgraded to stage II gears, and a custom built billet torque converter. I've also done the DIY big short ram Napa intake and 3" dp to 4" back and a banks big hoss chip. Truck has stock engine, injectors and Turbo(all with around 140k miles) I've been pondering either doing a rebuild on the Turbo with a banks quick spool side and maybe a wicked wheel. But I've also been thinking about stage I injectors. Let me know what you guys think and what you'd do if you had $1200-1500 to play with.
kuneefay is offline
post #2 of 3 Old 06-09-2013, 10:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Rosewood stage 1's, custom tuned ts chip with tony tunes, and a DIY intercooler
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 06-10-2013, 09:30 AM
EflumE's Avatar
Quoted: 29 Post(s)
also might want to check your current HPOP. if it's weakening you would want to look into an upgrade to support injectors
-Eric-
96 cclb, baby swamps, TS 6 position w/swamp's tunes, billet wheel, 1.0 housing, diy ebpv delete w/plugged pedestal, 3" downpipe to 4" exhaust, 6637, boost, egt, trans gauge, fully built trans, 203* tstat, 08 diff cover, airlift helper springs
218,000
9 inch skyjacker on 37" interco M16's
EflumE is offline
