d60 brake mounts - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-09-2013, 08:44 AM Thread Starter
dr.deere's Avatar
Quoted: 19 Post(s)
d60 brake mounts
anybody ever tried to swap caliper mounts on a d60? I have kingpin axle with slidepin caliper mounts and am curious if I can swap the bolt on caliper mounts from a newer axle like my 94 ttb that the 60 will be replacing after I regear
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #2 of 20 Old 06-09-2013, 09:37 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Not going to happen. The mounts are part of the spindle. The spindle is either king pin or ball joint. The king pin only come with pin on caliper. The ball joint come in either pin on or bolt on, they can be swapped but not the king pin and ball joint
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 20 Old 06-09-2013, 10:52 AM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
brad - i think you mean knuckle
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 20 Old 06-09-2013, 11:29 AM Thread Starter
dr.deere's Avatar
Quoted: 19 Post(s)
Actually if you pull the spindle off the knuckle you can get caliper mount off just not sure if spindle bolt patterns would be the same to swap caliper mounts
dr.deere is offline
post #5 of 20 Old 06-09-2013, 11:34 AM
the baconator
Quoted: 149 Post(s)
not following what you are saying.
post #6 of 20 Old 06-09-2013, 01:42 PM
Quoted: 4 Post(s)
Yes, knuckle
The spindles are interchangeable between d60s but the KNUCKLE is where the caliper mounts.
You can NOT use a 94 knuckles(ball joint, pin on calipers)on the king pin axle(king pin, pin on calipers)
post #7 of 20 Old 06-09-2013, 04:54 PM Thread Starter
dr.deere's Avatar
Quoted: 19 Post(s)
The caliper mount separates from the knuckle on the one I have In the garage. I don't want to change knuckle just the caliper mount
dr.deere is offline
post #8 of 20 Old 06-09-2013, 05:01 PM
the baconator
Quoted: 149 Post(s)
pics please. that is the only one i have every heard of
post #9 of 20 Old 06-09-2013, 05:04 PM
boozinag's Avatar
The calipers mount to the knuckles, therefore I gather that he is asking if he can swap TTB knuckles or other onto his KPD60
Gerry
'97 CCSB f-250 4x4 auto, 6pos chip w/ canned tunes, AFE intake, 4 in exhaust, 3in dp, 3.55 gears,
Dana 60 rebuilt and waiting to be installed
184k
boozinag is offline
post #10 of 20 Old 06-09-2013, 06:04 PM Thread Starter
dr.deere's Avatar
Quoted: 19 Post(s)
So I was wondering if part on left can be swapped with a bolt caliper style peice from a newer axle to this one still using part on right
Name:	ImageUploadedByAG Free1370829770.509173.jpg
dr.deere is offline
